Tire / Wheel Fitment Questions
#3692
I am looking at picking up some Work Emotions T7R in the 18x9 setup for my Evo 9. Im curious as to see whats the most optimal setup for a performance standpoint. I'm currently on swift springs with no rolling/pulling work done, but I will eventually go to coil-overs. What kind of offset would you recommend and tire size? I'm trying to avoid pulling but I don't mind rolling if its required. Also, would that wheel setup be too aggressive if I put some winter tires on it? Or should I just buy some 17's and run winter tires on that?
Curious to see what you guys will recommend.
Cheers,
Russ
Cheers,
Russ
#3693
Cheers,
Russ
Cheers,
Russ
Yeah, this question gets asked frequently. Theres no exact answer but generally speaking, I feel the range falls into this:
17x8 to 17x9 w/an offset range of +34 to +38 (tire size 255/40)
18x8 to 18x9 w/an offset range of +34 to +38 (tire size 255/35)
If you find an exact size you want, post up here & I can run it on the calculator to give you a better idea of the fit
Regarding the winter tires, it would be great to get those mounted to some 17's & leave your 18's for the spring / summer & fall work
Joe
#3694
Hey Russ
Joe
Joe
It seems that the noob me didn't do enough research because they don't offer an 18x9 setup. Only 18x8.5 or 18x9.5.
http://www.workwheelsusa.com/wp-cont...ZING-CHART.pdf
Which way should I swing? 8.5 or 9.5? Also, would fender/spacers be required for this type of work?
#3695
Hey Joe,
Most anything in the 9.5" variety, except for the +38 would need a rear roll. If you would consider the 18x9.5 +30, this would need a slight rear pull & possible rear bumper bolt relocation (depending on tire size)
Now, I am not familar w/this wheel but a front spacer is more likely than not. (did a quick forum search on the T7R & got no hits).
#3697
Was wondering if someone knew from the looks of what the offset is. This is Works CR Kai wheels, 18x8.5. I can't find anywhere on it saying what the offset is and the only thing I know is per this sizing chart it is either 30, 38 or 47 off set. I'm gonna assume it's 30 or 37. Now will 18/8.5 30 or 37 offset wheels be fine for 265/35/18s? Am currently on 245/40/18.
#3698
#3699
I checked and it didn't list the offset.
Another person posted same wheels 18/8.5/30 offset and I believe they look exactly the same?
https://www.evolutionm.net/forums/at...e-img_4900.jpg
#3700
Would be interested in seeing the back side of the wheel myself. The size & offset must be stamped for ID purposes. Strange seeing a convex wheel w/a low +30 offset
Edit: You might be right, heres a FS thread showing that +30 wheel (its the 8.5 width that gives it that look. The 9.5" has a flatter face) / https://www.evolutionm.net/forums/sa...5-w-tires.html
#3702
To properly run that wheel, a tight rear roll, fender pull & bumper bolt relocation is needed
Hate to be negative on your idea, but it is a tough wheel to fit in the rear
Other questions, let me know
Is2scooby (Mar 23, 2018)
#3703
Gents
Just installed my track wheels. Advan RGII 17x9 +29 wrapped in the fat Federal 595 EVO 265/40's. These tires are actually a 275 width but fit OK on the 9" wheel, even though 265 is the widest width allowed
Its hard to see in the pics, but the tires look great w/the Advans. Hadnt run them on the street in many years, but since Im not tracking currently, Thought Id put them into service.
#3705
Gents
