Tire / Wheel Fitment Questions
Old Apr 30, 2018, 06:43 PM
  #3781
Raptord's Avatar
Ended up solving the problem by cutting off the part of the flap where the wheel was rubbing Downside is that this included trimming the spot where the inner screw would go, however I've had only the 2 outer screws for a while on one side and the flap stays positioned correctly so I'm not too worried about it.
Old May 1, 2018, 11:43 AM
  #3782
city's Avatar
I have racecomp gtworx lowering springs with stock oem bilstein shocks/struts. Will 17x9+35 wheels with 255/40/17 tires, or 18x9+35 wheels with 255/35/18 tires fit without any fender rolling/pulling and not cause any rubbing and clear the front and rear brake calipers? Car is driven daily and maybe to the track once in a while. Trying to find a good wheel and tire setup.
Last edited by city; May 1, 2018 at 11:54 AM. Reason: edit to include type of driving conditions
Old May 1, 2018, 11:53 AM
  #3783
Raptord's Avatar
You'd need a bit of a rear fender roll for that I would think. Even on stock 17x8 +38 wheels, my 255's would sometimes rub on the rear fender with multiple passengers and going over certain bumps.
Rear brakes aren't an issue, front brakes will depend on the exact wheel's design. What wheel are you looking at?
Old May 1, 2018, 12:01 PM
  #3784
city's Avatar
Thanks for the reply Raptord! Would a 245 tire instead of 255 clear without any rubbing and not need any fender rolling? I'm interested in a wheel thats lightweight and forged. Not too sure what is out there that looks good and easy to clean so nothing with lots of spokes in the wheel design.
  #3785
Received 1,384 Likes on 1,317 Posts
I concur
Certainly a rear roll needed. A rear roll is almost a given w/wider than stock tires. Might as well get that done & done correctly
As noted, no easy way to advise on the front caliper clearance. Give us the make / model & offset & we will see if others have used that spec on the EvO
Old May 1, 2018, 12:17 PM
  #3786
A rear roll will likely be needed & usually good insurance against rub. You can only rub a tire so many times before damage occurs
If you have other questions, let us know
Old May 7, 2018, 07:52 PM
  #3787
Gideon281's Avatar
I apologize if I have asked this before, but I am getting a little gun shy.
I have an 2005 EVO 8, looking forward to installing the following wheels.
Rota Grid in Flat Black 18x9.5" 5x114.3 ET20
Note: Fender pulling in the rear, and possible 3-5mm spacer upfront expected. Relocated front bumper fastener ?
1st question:
What size tire would you recommend? 255/45/18?
2nd Question:
Any brand or specific tire. It is HOT af where I live and 80-90% humidity.
Old May 7, 2018, 11:31 PM
  #3788
jwalleg's Avatar
18x9.5 +24 ce28s. What’s the most I would have to do to fit these with 255s?
Old May 8, 2018, 06:48 AM
  #3789
I have an 2005 EVO 8, looking forward to installing the following wheels.Rota Grid in Flat Black 18x9.5" 5x114.3 ET20
1st question:
2nd Question:
Hello. The +20 is very, very tough to fit.
For sure, a rear fender pull, roll & the rear bumper bolt relocation is in order. Regarding tire size, you really need to run a light stretched tire IMO. Certainly not a 45 series. You should stick w/a 35 series based on the +20 offset. You should consider a 245/35 or 255/35
Regarding brand. Ive been running the Federal EvO 595's. Really like the tire for the street. It has a 240 treadwear rating to give you an idea of hardness.
Really would like to see you run a higher offset wheel, but I understand that these low offset wheels look good
Old May 8, 2018, 06:51 AM
  #3790
To get a +24 to fit w/out rub, The rear will need the full treatment. Tight rear roll, slight rear fender pull & the rear bumper bolt relocation
+24 is a very aggressive offset, especially when combined w/the 9.5" width
Old May 8, 2018, 07:17 AM
  #3791
Astro_Train's Avatar
MinusPrevious is 100%
What suspension are you running on your Evo?
If you are on Swifts springs (1.4 inch drop Fronts and .8 inch drop Rear) for example, you can get away with just a roll in the rear. The fronts will be fine at that ride height but they require an 8 mm spacer up front so your effective offset will be +16. The rears I had no problem running with just a mild fender roll and -1.5 camber with the car lower than what you would be on Swift springs .. I like using this spring as a "test bench" since it is a nice functional drop. A 255 will give you less hassle so you are smart by choosing it over a 265.
a 255 is a good street tire size. It is a very mild stretch on a 9.5 rim... also a few tires run wider than others so pay attention when choosing a tire brand.
This is a pic of my car with those exact specs on a 265... the car is much lower than it would be if it was on Swift springs which is what I ran prior to getting coilovers.
Is2scooby (May 31, 2018)
Old May 13, 2018, 08:17 PM
  #3792
city's Avatar
So the wheels I have narrowed it down to are Volk TE37 17x9+22 and Volk CE28N 17x9+22 and want to run 245/40/17 or 255/40/17 size tires. Will I need to run any spacers to clear the stock front bembro brake calipers for these two types of wheels? And beside rolling the rear fenders, will a rear fender pull be needed to prevent tire rubbing?
Thanks!
Old May 14, 2018, 05:55 AM
  #3793
Thanks!
Well thats a nice wheel for sure. No way to tell if the caliper clearance is proper w/out doing a test fit or previous experience. I did find a thread that seems to match your spec here: https://www.evolutionm.net/forums/ev...-calipers.html
Certainly looks like they fit, but its way too close. I think the spec is 3-4mm (.157") of clearance needed
The +22 is super tough to fit but what is helping is the 9" vs 9.5" width. Personally i feel a slight rear pull may be needed & possible rear bumper bolt relocation. You can try it w/a nice tight flat rear roll & see what you think. I would remove the rear strut & disconnect the rear sway bar & check the clearance.
city (May 14, 2018)
Old May 14, 2018, 06:57 AM
  #3794
Thanks!
The CEs will clear without spacers.
CEs sample..
https://www.rx8club.com/rx-8-parts-s...8-17x9-195397/
as for the TEs.. I am not sure if they clear the calipers without spacers. Maybe someone that has ran them, will chime in.
city (May 14, 2018)
Old May 14, 2018, 07:08 AM
  #3795
Morning Roger
This guy is noting less than 1mm of clearance on his 17x9 +22"s. That is too tight (spoke flex!)
city (May 14, 2018)
Quick Reply: Tire / Wheel Fitment Questions
