Tire / Wheel Fitment Questions
city (May 14, 2018)
#3797
Well thats a nice wheel for sure. No way to tell if the caliper clearance is proper w/out doing a test fit or previous experience. I did find a thread that seems to match your spec here: https://www.evolutionm.net/forums/ev...-calipers.html
Certainly looks like they fit, but its way too close. I think the spec is 3-4mm (.157") of clearance needed
The +22 is super tough to fit but what is helping is the 9" vs 9.5" width. Personally i feel a slight rear pull may be needed & possible rear bumper bolt relocation. You can try it w/a nice tight flat rear roll & see what you think. I would remove the rear strut & disconnect the rear sway bar & check the clearance.
The CE28SL does not show as clearing the caliper in 17x9.5 or 9 inch model per Rays site.
Here is a video that showcases both wheels.. 17x9 CE and 17x9.5 TE. Personally I think the TE looks better but that is subjective.
city (May 14, 2018)
#3798
Thanks MinusPrevious and Astro Train for both of your feedback, I really appreciate it!
According to Rays website, it looks like the the TE37 Saga 17x9.5+22 will also fit the EVO VII & IX.
Do you have any pics of your new wheels Astro Train? Also what tire size are you running on those TE37SL's? Did you have to do any rear fender work or rear bumper bolt relocate?
I really like the bronze color and leaning towards the TE37 Saga in 17x9.5+22 in. But if the +28 offset on the TE37SL will fit better without any fender work, then I would just get the SL. I'm on stock Bilstein shocks and GTWORX springs.
MinusPrevious (May 14, 2018)
#3799
The +28s I ordered will be here tomorrow. I am mounting 255/40/17s Michelin Pilots the next day. I would have preferred to go with a 255/40 Federal since they run wider and are more like 265/40. 265/40s are only made by a few manufacturers so the next option are 275 but I DON'T want to raise my car from where it is now. So the Pilot Sports will be a good gauge. My rear fenders are rolled flat. Bumper bolt has not been relocated... probably will not need to be unless I up the tire size as I mentioned.
As for your being on GTX Worx Springs.. you can run either the +22 or the +28 with likely just a roll in the rear because these springs are a very mild functional drop. Some negative camber will also help. I always say go with the higher offset unless you like the Sagas better. I would stay with a 255/40 to be on the safe side.
I have not confirmed this but I believe this Evo is running 17x9 +22. So the wider +28 would be about the same since the .5 inches adds about 6-7 mm on each side He is also running a fairly wide tire.
here is a pic of that same car but appears to be running a meatier tire... probably a 275.
Astro_Train (May 17, 2018)
MinusPrevious (May 17, 2018)
#3803
I run a similar spec: 17x9.5 +30 in which I needed all the above. I am running some aggressive rubber which made the fit tougher (275/40/17)
Paint cracking can happen & just be prepared to treat it. Sand the cracked paint down & re-coat & seal
#3804
Hi All,
I'm currently running 245/35/18 Federal RS-RR's on stock Evo X GSR wheels (18x8.5 +38) and am thinking of upgrading to 255/35/18 Toyo R888R's.
I'm lowered on Ohlins coils (at the same height as Swift springs would be) and have rolled rear fender lips (stock bumper bolts).
Tire Manufacturer spec sheets show:
1. RS-RR section width of 9.8 and tread with of 9.3 with an overall diameter of 24.7
2. R888R section width of 10.2 with a tread width of 9.6 and an overall diameter of 25
3. Delta = Section Width +0.4, Tread Width +0.3, Diameter +0.3
Does anyone have any pics and/or thoughts on real world fitment of the R888R's on my car?
Thanks!
Thanks!
#3805
But yes like Previous said. The issue fitting wheels on the 8/9 is usually the rears. So you can push the fronts a bit more than the rears. +28 has been done plenty and is very popular.
#3806
Hi All,
Thanks!
Thanks!
Used to run a similar tire on my X wheels. Ran the Toyo T1R 255/35 w/an inflated section width of 10.1". Wasnt even rolled at that time. Heres a pic from almost 10 years ago
Joe
Is2scooby (May 31, 2018)
#3809
Thanks, Joe. Looks great! (My car is a Wicked White IX as well). I think I’ll hit Tire Rack up today. ;-)
