Tire / Wheel Fitment Questions
Astro_Train (Jun 26, 2018)
#3873
^^ as always you are on point Joe. Yes totally tucked in and that was my goal. Appreciate your guidance. I will likely be doing the rear bolt relocation eventually. I ran enough camber to avoid doing it for now and the ride height isn't totally dumped so the combination of both has kept the rubbing from occurring int the rear. +28 to +30 seemed to be the breakpoint where that bolt HAS to be moved if I was going any lowered. So we played around with the ride height where I was not running any further camber than -2 and car looked good and I have not encountered any heavy understeer.. I also balanced the rake more so the front isn't so much lower than the rear as it was before.
MinusPrevious (Jun 26, 2018)
#3874
We're on the same page Roger. Yeah, would like to see your ride height a tad lower in the rear.
My set-up was centered around track performance so we had to do all the necessary tricks to avoid any rub (some of the rear treatment would not pass your approval on appearance)
#3875
MinusPrevious (Jun 27, 2018)
#3876
Federal tires usually are a little bulky. Couple friends had them before and they all seem to fit a size bigger. I think that stance looks mean. Maybe a quater inch lower in the rear. I like when then back isn't lower than the front how a normal evo looks from factory
The following 2 users liked this post by MP Evo:
Astro_Train (Jun 27, 2018),
citrys (Jun 27, 2018)
#3877
Looks really nice!
I can order only Federal ST-1
#3880
https://www.willtheyfit.com/
For sure on the rear roll. Certainly cant have any rub! Would rather see you on a bit higher offset above +30, but i understand the +22's look real good
Make sure you check on the front caliper fit. Hopefully no spacers are needed
Joe
Nicolas (Jun 27, 2018)
#3882
+30 pushes the wheel a bit further into the well & makes fitment easier & we could consider running a 255/40
But if youre set on the +22's, the 235 tire helps w/fitment & the rear roll is likely all that is needed
Heres my ride sitting on a Federal 265/40 (really a 275) on 17 x 9 +29's (White RS)
Also, Astro Trains Red RS w/ 17x9.5 +28 TE37SL 265/40 (Federals)
The following 2 users liked this post by MinusPrevious:
Is2scooby (Jun 28, 2018)
#3883
i see what you are saying, to go with an offset of around +30 so to be able to use a wider tire without fender work. My purpose was to go as aggressive as i could by using a "smaller" tire so to be faster. The idea was if i could get something from both worlds. Beauty and performance. We will see how it goes when i put the rims on the car.
Both cars in the photos look really good...
The calculator you posted was really helpful. It shows that the rim will go approximately 3cm closer to the fender and that was what i was looking for
#3884
you'll need a 10mm spacer up front to fit those. So your total overall offset will be +12mm up front and yeah I'd recommend a slight roll in the rear all depending how low you plan on taking it.
#3885
