Tire / Wheel Fitment Questions
Old Jul 15, 2018, 06:43 PM
  #3916
Received 1,384 Likes on 1,317 Posts
Originally Posted by MP Evo
thanks i was going for flush and simple clean. Car is dirty in the pictures since i didn't sleep at my house it got caught in the rain. A buddy said to lower it a little but then ill probably scrape on some of my roads and such and def will need to do rear quarter work
Yeah, w/a 9.5" wheel & the +25 offset, rear fender work is required. Yes, reducing the fender gap will really enhance the look, for sure
Old Jul 19, 2018, 05:36 PM
  #3917
MP Evo's Avatar
Here's a couple more pictures for you guys. I should of did a 245/40 maybe would of had more sidewall to fill it with.
Old Jul 19, 2018, 05:57 PM
  #3918
city's Avatar
MP Evo nice wheels looking good man! Hey what kind of suspension are you running on?
Old Jul 19, 2018, 07:23 PM
  #3919
Great looking pics for sure. Yeah, we need to level this sled a bit, once you do the rear fender clearancing
Good pic taking
Old Jul 20, 2018, 01:02 AM
  #3920
Callum Gracie's Avatar
Has anyone run Enkei PF01 18x9.5 +22 or+35? Apparently these are good for clearing Brakes. Can anyone confirm the +35 will clear the front? If not I'd be happy to run +22. Tyre will be a stretched 245/40/18 AD08r as I already ordered them for my previous wheels that I cracked one of them. The PF01 EVO in SBK look tasty.
Old Jul 20, 2018, 05:07 AM
  #3921
Astro_Train's Avatar
the 2 offsets you are looking at have two completely looking faces and lips on them. The +22 is the one you are looking at above. They will clear on an Evo X without spacers. But I am not 100% sure on a 8/9. Do some searching on the forum for it or just google search. Or call Enkei directly. Unless someone here chimes in that has ran them in the past.
Callum Gracie (Jul 20, 2018)
Old Jul 20, 2018, 05:41 PM
  #3922
Think I will go down a different path. 18x9.5 +25 SSR SP5 is on sale for only costing another 500 than the PF01.
Old Jul 20, 2018, 05:44 PM
  #3923
Those SSR's are nice looking, just note that they will be tough to fit w/the +25 offet (rear roll & pull will be needed). Depending on tire size, the rear bumper bolt may need to be relocated. Also, the front may not fit over the Brembos w/out a spacer. (few wheels fit w/out a front spacer)
They do look nice for sure!
Old Jul 20, 2018, 07:35 PM
  #3924
They look amazing. I will be running a 245/40 because I had already ordered them for 18x8.5. Supplier said this size clears brembos fine as he has supplied to many evos locally. I'll roll rears and raise a little and hopefully not hear scrub too often.
Old Jul 20, 2018, 07:59 PM
  #3925
Sounds Good. Make sure you post up some fitment pics & your impressions after the install
Thanks,
Old Jul 21, 2018, 05:50 AM
  #3926
MP Evo's Avatar
the car has the d2 with swift springs stm sells for there drag coil setup.
Old Jul 21, 2018, 05:51 AM
  #3927
MP Evo's Avatar
Good pic taking
Haha level the sled. I was going to drop it maybe a half inch all around see where that leaves me. Haha I'm scared to roll the rears if the paint might crack
Old Jul 21, 2018, 07:20 AM
  #3928
crack
Yeah, to properly run the wide wheels & wide rubber, we have to cross that hurdle of not wanting to modify the rear fenders. The paint will likely crack unless extreme care & time is taken. If it does crack, sand & touch-up will correct & will not be seen
Old Jul 23, 2018, 05:26 AM
  #3929
pls1968's Avatar
Need advice on fitment, Right now I currently use a Hoosier QTP 26x9.5x16 with 22mm spacer in the front and 20mm spacer in the rear to clear my brembos, I'm running a 16x7 Slipstream. I'm thinking on getting the 255x50x16 Hoosier Drag Radial but I'm worried if it will rub, my rears are rolled but not the front, with my current setup I have never rubbed, thanks in advance for your help.
Old Jul 23, 2018, 05:55 AM
  #3930
I converted the QTP over to this Metric size = 241/53/16
Just need to know what the offset is on the 16x7 Slipstreams?
Quick Reply: Tire / Wheel Fitment Questions
