Tire / Wheel Fitment Questions
Old Nov 25, 2018, 07:45 PM
  #3976
nbnie's Avatar
Yep, no problem. A 255 is the max size recommended for the 8.5" wheel.
Thank you so much, so I can just purchase the 17*8.5 +30 rpf1 sbc and 255 tires, right? haha, time to buy
Old Nov 25, 2018, 07:47 PM
  #3977
Received 1,384 Likes on 1,317 Posts
Just keep in mind, that the 8.5" +30's have a diff face than the wider wheel (some guys dont like it)
And you will definitely need a roll w/the +30
Here they are:
Old Nov 25, 2018, 07:50 PM
  #3978
nbnie's Avatar
Omg pls no fender roll... so sad. Any other recommendations for wheels? Which can meet the tire and also light?
Old Nov 25, 2018, 07:52 PM
  #3979
You have to get the roll to fit these wider wheels w/the wide rubber
Heres my ride w/the following: 17x9.5 +30 running a 265/40 tire ( a lot of rear work to get this to fit correctly)
Old Nov 25, 2018, 08:02 PM
  #3980
nbnie's Avatar
Originally Posted by sujinX
all 17x9 rpf1 have spacers. from all my research the +35 is the worst offset, needs 20 mm spacer up front and a small in rear (maybe tire dependent)
+22 someone said a 5mm spacer up front only, but was close.
17x9.5 et18 clears front but is close to fender, the rear sticks out pass fender (no spacer setup)
17x9.5 et38 needs 20mm spacer (essentially being a et18) and fits perfectly in rear.
of course fender work is needed, mainly tire dependent.
Sorry to ask, is 17*9.5 et 18 gonna work without fender rolling?
Old Nov 25, 2018, 08:05 PM
  #3981
Thats the reason for the RPF1 +38 in the rear (again its possible to fit 255 rubber w/this wheel w/out a roll. (its close). Ive heard the R888's run wide!
When you run the +38 in the rear & run the +38 up front w/the 20mm spacer it turns the +38 into a +18 up front . Example: 38 - 20 = 18. No way the +18 will fit right in the rear (too much poke to fit correctly)
Old Nov 25, 2018, 08:12 PM
  #3982
nbnie's Avatar
Thanks man,
I m very into rpf1 sbc now but only few size option for me now ,17*8.5 +30 17*9 +45 (also +22 I believe but hard to find now) 17*9.5+18 or 18*9.5+38. I want a flush view and most likely no fender roll since all the local shop has no such service. Which one should I choose? Prefer 255 tires for track day use.
I m new here, very appreciate ur help
Old Nov 25, 2018, 08:14 PM
  #3983
nbnie's Avatar
looks so good. So sad I dont know how to do the fender work
Old Nov 26, 2018, 05:58 AM
  #3984
There are certainly body shops that are experts on rolling. Its not that big of a deal. Most of us, here, on the boards have had the work done
If you have other questions, let me know & hope to see you out here on the boards often
Joe
Old Dec 9, 2018, 08:23 AM
  #3985
Evohno's Avatar
Advan rz flush fitment
Hello fitment gurus
I'm looking to buy a set of Advan rz's for my IX but I'm unsure what offset to go with. I want them to be flush without having to roll the fenders and definitely no rubbing. Car is still on stock suspension but I plan to get coilovers eventually. I am thinking 18x8 or 18x9.
I bought a set of 18x9 +25 and I absolutely hate it. There's an insane amount of rubbing on the wheel well plastic. They also stick out from the body quite a bit which I'm not looking for on my car.
Thanks!
Old Dec 9, 2018, 09:22 AM
  #3986
Originally Posted by Evohno
Hello fitment gurus
Thanks!
Hey alright, welcome aboard
Yeah, The right wheel choice is a tough recipe to find. From my chair, wheel fitment is certainly a compromise, meaning you have to be willing to give some things up (i.e. rolling fenders etc)
A general feel for a non rear roll wheel spec would be (IMHO)
  • 18x8 / 18x9 +34 to +38 (depending on tire size)
  • 17x8 / 17x9 +34 to +38 (depending on tire size)
One of the best wheels that required little work was the 5zigen FN01R 17x9 +35 (see pic)
Not even sure if they are still avail? (please consider rolling those rear fenders)
Old Dec 12, 2018, 09:30 PM
  #3987
EvoGrinch's Avatar
fitment
i am looking at putting volk te37 17/9 on nit nt555 255/40. not sure about offset or fitment issues as far as fender modification was wondering if anyone has this setup or insight.
Old Dec 13, 2018, 05:14 AM
  #3988
Yeah, the 17x9 is a good size wheel for the EvO. There are many that used the TE37 17x9 +22. This size will work but needs a fair amount of rear fender work to fit correctly (roll, pull & bumper bolt relocation)
I havent studied up on these wheels in a while, but if you dont want that level of rear fender work, go up in the offset. For example 17x9 +29 to +34. Let me know what offsets you find & i can work that up on the calculator & give you a better feel for what is needed to fit
Old Dec 13, 2018, 02:09 PM
  #3989
EvoGrinch's Avatar
I am looking at +40 offset and have stock height suspension if that matters, and i would prefer not to use spacers or modify fenders if possible. i previously had 255/40 on stock rims and i wanted to keep that same tire size if possible.
Old Dec 13, 2018, 02:53 PM
  #3990
+40 is a very safe offset & is 2mm further inboard than stock. This will fit the rear no problem running that 255/40
But, no way these TE37 will fit the front w/out a spacer. W/out a test fit or finding someone who has done this, the spacer size is unknown. Being that its a +40, the spacer would likely be very large & may not be doable. Anything over 25mm should not be used IMO
I recommend a diff wheel. See if you can find a 5Zigen FNO1R (17x9 +35). Theres a pic of it on post no. 3986. Let me see if i can find anyone whos run this +40
EvoGrinch (Dec 13, 2018)
Quick Reply: Tire / Wheel Fitment Questions
