Tire / Wheel Fitment Questions
#4126
Seriously bamboozled on how others got theirs so nice.
Nto3 Picture thread https://www.evolutionm.net/forums/ev...re-please.html
You really need a 12mm spacer as the min. 1-2mm of clearance is a bit tight & wheel flex could get into the caliper (keep an eye out for any caliper contact)
iD33 (Mar 25, 2019)
#4127
Quick Question - Just lowered my car and looking to get rid of that "hover-craft" look without having to roll the fenders. I have the stock MR BBS rims, and was curious would 10mm spacers rub? Saw and heard of some people were running 15mm spacers and didn't rub, while others had it rub. Just want that overhang gone!
#4128
My best advice is to do the rear fender roll at the min. If you run a 245/40, 245/45 or the wide standard 255/40, a rear roll will be needed running that 10mm spacer
#4129
The tire choice will certainly affect this. The stockers are a +38 offset & adding a 10mm gets the wheel to the effective offset of +28.
#4130
Im running RE-71 in 255/40R18 on enkei raijin18x9.5 +35 wheels. Set up worked fine with the small brake kit, but now that I'm switching to the stock brembo they don't clear the calipers. I thru in 2, 3mm spacers so essentially it was 6mm. still didn't clear by a tiny bit. So im leaning towards a 8mm but won't really know until i buy them.
so Im trying to see if anyone has run a set up like this before and what was the solution before i go out blindly buying spacers.
-Ohlins+rear rolled
-Ohlins+rear rolled
#4131
-Ohlins+rear rolled
-Ohlins+rear rolled
#4132
Great idea on the washers, ill give that a try and narrow it down. Now to figure out if the its gonna conflict with the fender clearance.
#4133
Up front, you should be OK but expect front liner rub at lock positions. Depends on your ride height. Its best not to run too low up front (consider no less than 25 3/8" from ground to under the fender lip)
#4134
So it looks like I’m gonna need to run 18mm spacers up front. New to this spacer thing, but would these be what I need? I already got the arp extended studs so I was gonna ditch the bolts these come with.
Adding a spacer to that +35 / 9.5" you will be needing some light rear fender clearancing (likely a rear roll is all that is needed)
#4136
Thanks in advanced!
#4137
Yep, you got to run them
Ebay & others have them. The alum ones are the best but the composite ones work as well (double check the hub bore on that wheel but pretty sure its 72.6 & we know the EvO is 67.1)
If you track your EvO, the alum ones for sure @Felix_VIII
#4138
With the Hub Centric Ring - 67.1mm ID to 72.6mm OD (Stock bore to NTO3S bore)
Without the Hub Centric Ring - Ichiba slip on spacer for Evolution is 67.1mm
#4139
I used the 67.1mm ID to 72.6mm OD (Stock bore to NTO3S bore) aluminum Hubcentric Rings (Pack of 4) -... https://www.amazon.com/dp/B00CH8MBUU...p_mob_ap_share
It fits perfectly on the wheels.
#4140
