Tire / Wheel Fitment Questions
Old Apr 7, 2019, 08:41 PM
  #4141
dyablo's Avatar
double post.
Old May 10, 2019, 03:37 PM
  #4142
WelDun1's Avatar
Wheels & Specs that fit Evo 8/9/X
Can we get a list going of known Wheels/sizes/mods that will
a) Clear Brembos
b) Clear Strut
c) Clear Fenders (not as much a necessity as the other two)
Not starting a new "Stance" or "Aggressive Fitment" pictures thread. I just think it would be beneficial to so many ppl to have a list of wheels sorted by Brand, sizes & maybe a little info on mods such as spacers, fenders Rolled n Pulled etc.. I know there's a lot of ppl who don't know much about wheel fitment, or what effect offset even has on the fitment.
I only know of a handful that fit w/o mods, but I could just start a list based off of what ppl post.
Just a thought. I've been having a hard time finding exactly what I want compared to what will work & if there was a list, I'd have less of a headache right now lol
List sorted by Brand then Size
MB Battles
18x9 +30
245/40/18
Kim Leverström (Sep 26, 2019)
Old May 10, 2019, 04:08 PM
  #4143
Bmurray's Avatar
My first setup that I ran (if I remember correctly - didn’t require rolled fenders)
MB Battles
18x9 +30
245/40/18
WelDun1 (May 12, 2019)
Old May 11, 2019, 05:52 PM
  #4144
GreekEvo9's Avatar
Yo man off the top of your head do you know if Weds Sport - RN-05 18x9+ 34 with 245/40/19 would have any issues?
Old May 11, 2019, 06:06 PM
  #4145
Received 1,384 Likes on 1,317 Posts
Hey @GreekEvo9
Cant comment on the front caliper clearance, but as far as rear fender clearance, the +34 in the 9" width gives you a lot of room for tire
That 245/40 should fit very nice & that 40 series will really give it a nice meaty look. Still would recommend a rear fender roll if you havent done than yet
Old May 12, 2019, 10:48 AM
  #4146
GreekEvo9's Avatar
Thank's man! much appreciated!
Old May 15, 2019, 10:01 AM
  #4147
Dallas J's Avatar
edit: Looks like thread got moved. Good job mods
heel2toe (May 15, 2019)
Old May 18, 2019, 08:41 AM
  #4148
DSMolition's Avatar
Have a chance to get a set or rpf1s but they are 17x9 +45. does anyone run this or should i just save up and get a new set of the the correct offset.
Old May 18, 2019, 08:50 AM
  #4149
@DSMolition
Yeah, that offset is way too deep. After all, our stock offset is +38. You would need to run spacers front & rear to make that work & the spacer size would likely be very thick (well over 1" / 25mm)
Your best RPF1 choice is the tried / true 17x9.5 +38
Old May 18, 2019, 09:10 AM
  #4150
DSMolition's Avatar
Do they make that size in SBC? i cant seem to find any. Thank you for the reply.
Old May 18, 2019, 09:15 AM
  #4151
Certainly have not kept up w/ RPF1 availability, sorry
Keep us posted on your search & what size you plan on going with
Old May 21, 2019, 04:04 AM
  #4152
DSMolition's Avatar
According to oakes they make the SBC in a 17 bx 9.5 + 18 or 17 by 8.5 + 30. To fit the + 18 with 255 40 tires do I need to do more than a little bit of camber and to roll the fenders?
Old May 21, 2019, 05:50 AM
  #4153
@DSMolition The +18's are really just meant for the fronts w/no spacer (RPF1). You can not run these in the rear effectively w/out a lot of rub issues.
Some have run the +18's in front & the +38's in the rear but you can not rotate
Your best bet IMO, is to run the 17x9.5 +38 all around so you can rotate the tires. That setup is what most 17" guys run in the RPF
DSMolition (May 28, 2019)
Old May 28, 2019, 07:37 PM
  #4154
DSMolition's Avatar
Does anyone run the Ray's gram light 57dr in the 17x9 +38 or the 18x9.5 +38. I can't find much info on them. I know I would need a spacer up front.
I'm about to give up on the rpf1 in SBC. They dont sell a good fitting wheel in that color anymore.😣
MinusPrevious (May 28, 2019)
Old May 28, 2019, 08:05 PM
  #4155
A
I'm about to give up on the rpf1 in SBC. They dont sell a good fitting wheel in that color anymore.��
Did some searching on the 57DR & did not find too much in the way of EvO (CT9A) fitment. With that +38 offset, youre right that front spacer usage might be required
The 9" width is very modest & so it the +38 (no poke w/that offset). That 18" in the 9.5 would likely have a bit better look & would poke just a bit more due to the 9.5" width & the fact that its 18" (18"'s have a better look IMO, unless you go aggressive w/the 17's)
Just a few thoughts (.02)
Quick Reply: Tire / Wheel Fitment Questions
