Tire / Wheel Fitment Questions
#4156
Awesome thanks for the reply! this is what's going on. I'm looking for a set of wheels so I can actually drive my car around again. now its on a a set if drag tires and 17x 8.5 +40 pfo1s with a 15mm up front. and I feel bad putting miles on it wrecking the tires so I need another set to swap. If I end up with a +38 odds are I wouldn't have to remove the spacers to swap the wheels.
I really wanted some rpf1s but bummed I can't get the size that would work well in black or SBC. I emailed about every wheel dealer and they only made them in +38 in special batches
Imo I like the way the gram lights look just wish there were more people who have ran them on the Evo. They are modestly priced and decently light maybe I'll give them a shot. . I'm open to ideas that won't brake the bank for a RR Evo!
#4157
DSMolition (May 31, 2019)
#4163
That wheel spec is a winner for sure. Great job
Heres what the size will look like as im sure ya know. Heres the thread if interested:
https://www.evolutionm.net/forums/ev...f1-teaser.html
DSMolition (Aug 13, 2019)
MinusPrevious (Aug 13, 2019)
#4166
The lower strut, as pictured, moves in unison w/the tire so i think it works. Remember, the tire flex occurs at the bottom so when it reaches the top, the tire, should return to normal.
Definitely check as you run it, but the first drive, taking some corners & such should prove this out
Wow, w/the wheel spec for sure. 10.5" w/the 285 is on the very aggressive side & personally think thats great!
#4167
Just tried to put on my 18x9.5 +38 rpf1 with a 20mm up front that I waited 3 months to get. Everywhere I read said they fit fine the 20 MM. but I have about 1 mm clearance between caliper and spoke I assume that's way too close and
I shouldn't drive it.. don't really wanna add more and make it poke more but I don't see another choice. I can fit like 3 playing cards in the gap
#4169
2-3mm or .090 min is what is considered safe clearance. Keep us posted please on your choice
#4170
I should have gone with 255 35 18s instead of 255 40 18s as they are rubbing a bit during turns. I'll probably let it self clearance the liners and leave the spacers untill I decide to do some tracking then I'll grab some 22mm spacers to make sure I have that 3mm gap.
EVO196 (Aug 14, 2019)
