Anti-Lift Kits Perrin vs. Whiteline in Street Mod
Old Apr 10, 2016, 05:09 PM
  #76
Terror Rising's Avatar
You've got it right.
Old Apr 11, 2016, 07:27 AM
  #77
kyoo's Avatar
Originally Posted by kyoo
yes, move the wheels forward after getting moved back w caster plates. check the STU thread i think someone took measurements
mine are in - would guess the wheel is moved forward about half an inch at least, and with 225/50-17 that used to rub with cirodesign caster plates, I no longer rub at all!
Old Sep 14, 2016, 11:44 AM
  #78
dave_evolvix's Avatar
This is why I'm here. Can't find a PSRS, nor can it be easily serviced. I'm going to buy the Whiteline KCA400M. Spoke to Whiteline and it's not an official part for the Evo 8/9 because it needs to be shimmed/spaced to fit. Which follows what is in this thread. What size spacers did everyone use, and where did they place it? Between sub-frame and bushing (top)? Diam x Thickness?
Old Sep 14, 2016, 12:10 PM
  #79
kyoo's Avatar
I went with the superpro bushings, happy, no complaints here
Old Sep 14, 2016, 12:31 PM
  #80
mrfred's Avatar
Pick up some stainless washers at your hardware store. I think you'll get different opinions on whether to put the washers above or below because it will affect the antilift response slightly. I put mine below as this will very slightly improve the roll center.
Old Sep 14, 2016, 03:12 PM
  #81
Are the superpro bushings offset?
My understanding was that shimming was to prevent subframe/control arms from rubbing/hitting? I suppose that my priority should be geometry (Roll center, Anti-Lift, etc) but I just want to move the wheel forward to fit bigger tires.
Old Sep 14, 2016, 05:39 PM
  #82
mrfred's Avatar
There have been varying reports on the control arm rubbing the frame or subframe with the KCA400M. I didn't have any issues.
Old Sep 14, 2016, 07:32 PM
  #83
kyoo's Avatar
yes, that's why i got it. the caster plates moved my wheel back, and the superpros moved it back forward
Old Sep 15, 2016, 04:10 PM
  #84
Do you know how far offset they are? I didn't find any info that suggested the part was offset, just a direct replacement.
Old Sep 15, 2016, 09:20 PM
  #85
kyoo's Avatar
http://www.superpro.com.au/find/supe...999500378/vid-
it's in the definition, but i don't know how far offset
Old Sep 16, 2016, 07:05 AM
  #86
Excellent. Thanks for the link. I only found the DURO3739K which (as you noted in the description) is NOT offset
Old Sep 16, 2016, 07:06 AM
  #87
kyoo's Avatar
ohh gotcha. glad to be of help!
Old Sep 16, 2016, 09:33 AM
  #88
mrfred's Avatar
They do have an offset version. I have it in my hands. The offset is not quite as much as the Whiteline. Its probably 1/8" less.
Old Sep 16, 2016, 03:49 PM
  #89
Looked at my post, I was pretty unclear...
SuperPro DURO3741K = Offset
SuperPro DURO3739K = Stock
mrfred
154
Sep 12, 2023 10:19 AM
Dallas J
Sep 15, 2017 05:54 PM
evojesse
Jun 27, 2017 12:08 PM
Jonno99
Sep 12, 2016 03:35 PM
J!n K@z@mA
Mar 31, 2016 03:14 PM
Quick Reply: Anti-Lift Kits Perrin vs. Whiteline in Street Mod
