Help Need plz.....
Old Dec 30, 2011 | 10:09 AM
the lambo kille's Avatar
Help Need plz.....
Hello everyone
My evo 9 SE got the new shoe ( dunlop direzza )
after installing the tries i i am facing 2 problems. 1 is when i accelerate the car my car goes on the left side 2nd problem is when i m driving around 40+ speed car is going on right side i even did alignment but problem is still standing
Old Dec 30, 2011 | 10:25 AM
vortico's Avatar
Are the tires directional? They would say on the sidewall.
Old Dec 30, 2011 | 12:57 PM
deylag's Avatar
Yea to my knowledge the Direzza Z1 star spec is a directional tire. It has to be facing the right way and you can tell cause the tread will show the proper direction.
Old Dec 30, 2011 | 02:09 PM
yes i have checked directional mark is in the right way.... plz helpppppppppppppppp...
Old Jan 2, 2012 | 10:20 AM
Neal@tirerack's Avatar
Hard to say really w/out driving it. Best to take into a shop and have them diagnose what's going on in person.
Old Jan 3, 2012 | 08:22 AM
okay guys i recheck the alignment was out!!!, a bit from lift hand side that y my car was pulling on the lift hand side after 3000 rpm...now lift hand side problem is almost fix....but the big problem is right hand side still the car pull on the right hand side and guy who checked my car he said i have to change the Suspension coz camber is bend or it's not on the right place bla blaaaa !!! and other guy was saying first change the bushing!!! guys my car's miles are only 36!! then y i have to change the bushing ?..... can any of u can give me the right advice plz.
Old Jan 4, 2012 | 10:53 PM
barneyb's Avatar
The upper bolt that connects the front strut to the knuckle is adjustable for camber. There are two settings. You might want to check that the two sides are set the same. The bolt head has an arrow on it. If the arrow points in camber is 1 degree and if it points out camber is 2 degrees (or thereabouts). Also, if the bolts point correctly but camber is off you may be able to correct some of this by changing one bolt.
Old Jan 5, 2012 | 10:57 AM
ohhh i c thank bro,i will check and update u on the same!
Old Jan 6, 2012 | 08:10 AM
hey barneyb,
as u said i have check, i have opened the hood removed the chamber covers left hand side bolt seem to be right in place,but right hand side bolt was not in the right place it seem it was rotate in 2 degree or more!! however if u want i can take the pic and show u!!!i m sorry i m not having much knowing about the cars!!! ans i really appreciate if u help help me more to fix my car!
Old Jan 6, 2012 | 11:11 PM
barneyb's Avatar
I was referring to the adjustment available at the knuckle but I now understand you have camber plates installed.
Old Jan 7, 2012 | 08:17 AM
73DatsunZ's Avatar
Have a proper shop go over the alignment in your area that does modified suspension cars. If you aren't too too mechanically inclined you may not understand what some of these guys are saying. Its definitely an alignment/ suspesion error.
Old Jan 7, 2012 | 11:54 AM
i have showed in many different shops who do alignment i even have spend much money, but still cant solve the problem now i m planing to go to the company.
Old Jan 7, 2012 | 12:41 PM
this is the problem i guess,This how it look like!!!
and this is the right!!!
silver9mr
24
Jul 13, 2019 02:18 PM
blkmkIII
Northeast Region
Apr 21, 2011 09:45 AM
