Time for some new tires/brakes.
Hey everyone,
I did a search for this, but all I could find in a reasonable amount of time were threads from a long time ago - maybe I just suck a searching.....
I am about to buy a set of new tires, I was thinking that I was going to go with the OEM advans because I hear that they're a pretty solid choice. Are there any better choices out there for all season tires? Im looking for something with all around grip, longevity and something that isnt going to be too noisy.
I dont plan on doing any autox anytime soon, and I DD the car to and from work on windy back roads.
I am also about to replace the rotors and pads - same question, should I stick with the OEM setup or move to something else? The brake squeal isnt that big of a deal to me, but if there is a combo that would eliminate the squeal and still give me some bite, i would like to hear about it.
I read that centric blanks and hawk pads are a good combo, but i wanted to get some more opinions.
I dont plan on doing any autox anytime soon, and I DD (spirited) the car to and from work on windy back roads . Price really isnt a factor to me, I would rather spend a couple extra hundred bucks for quality parts.
On another note...ive been hearing some clunking when I am driving slow 30 and under. It sounds like plastic moving back and forth under pressure. I don't really know where its coming from though. It happens when I am going straight mostly, but also when Im turning either direction. It doesnt get worse when I hit a bump either. Any ideas what i should check, or what it could be?
thankssss
thankssss
im doing new tires brake and rotors right now also. the tires im geting you prolly dont want because their street use only. but im geting slotted rotors and hawk pads. the slotted rotors you dont really need there not gonna do anything different than normal rotor but their cool to have and that noise at 30 im not sure but you could check all that plastic under the front of the car; it could be banging around cause its all busted up?
For tires, I would recommend a set of Hankook V12s. They're not an all-season tire, but they're great in the rain, are quiet, and are awesome for DD. I've had them on my Evo for ~10,000 miles and they've still got plenty of life in them, even after 9 autocross events. However, if you just want one tire that can also get through snow, I probably wouldn't go with these
As for rotors and pads, a cheap set of blank rotors should do the trick, while a list of pads, as well as rotors, can be found here: https://www.evolutionm.net/forums/ev...ct-thread.html
I run the EBC Redstuff pads all around and I've been very happy with them. No squeal, only moderate dust when braking hard (auto-x), and instant bite. Hope that helps.
I really like the Continental ExtremeContact DW. Its a dry/wet tire with a pretty high tread wear (340) but is the wet tire to have right now for auto-x. For the NW rain its amazing to have as an all around tire. The forward bite of these are amazing, and they seem to have about the same grip in puddles as they do on wet ground.
BTW, you should update your sig
I auto-x'd the DW's last weekend cause it was a torrential downpour with mixed snow falling. I set FTD over the first group on 95% dry pavement when I was in almost 1/2 deep water. Then when we started clearing out I couldnt seem to get any faster. The just work that well with water.
No experience with the V12s though so I cant say which has is better in the dry. Noise is very low with these cause they seem to have a pretty soft sidewall, which also leads to a bit more comfort with my 700/900 lb/in rates. I can feel them squirm around but the rain grip has made me a believer.
Link to results. Overall results are a bit odd cause the morning was dry and afternoon very very wet. (when I ran)
http://www.oregonpca.org/events/auto...-time-results/
4g63xawd
62
Jan 6, 2016 03:25 AM
A Furr
May 21, 2013 09:53 PM
06MREvo
62
Jul 22, 2010 07:45 AM
[Cyanide]
24
Jul 17, 2006 02:59 PM
