Longer strut tophat mount studs/bolts
Yes something like that. essentially a 1/2" aluminum spacer plate to go between the tophat mounting surface and the underside of the strut tower.What this would do is allow me to have a better angle on the lower control arm, lift the car 1/2 inch and still keep the benefits of the Swift SpecR's spring rate.
So reduce the effect of the roll centre due to the drop from the Swift SpecR, give me better ground clearance for the winter, keep the spring rate. Toe will be affected minorly but easily fixed.
In theory :-)
FS[MidWest]: OEM GSR/MR Suspension Parts
ChrisM623
May 3, 2014 04:07 AM
ShanesEVO
Oct 20, 2013 10:03 AM
n2oiroc
Jun 7, 2013 06:55 PM
maramaralula
Oct 21, 2010 10:04 PM
