DANGEROUS D2 Coilover defect!!!
Old Apr 11, 2013 | 02:47 PM
Brent_si's Avatar
Originally Posted by EmeryatSTM
I can honestly say that we have put D2's through some crazy abuse and never experienced any kind of issues. Thats kinda crazy but I guess it could happen to anything. Defects are defects. With that said, if they were purchased from us we will gladly take care of the issue for you.
-Em
Unfortunatly they were not.
Old Apr 11, 2013 | 03:02 PM
SilverShadow03's Avatar
Where did you pick these up and have you contacted them yet to discuss your options?
Old Apr 11, 2013 | 03:40 PM
dtrackstar's Avatar
We're these bought used?
Old Apr 11, 2013 | 05:54 PM
Brent_si's Avatar
I got them on ebay from 70after. Payment went to kuruma motoring inc. I have contacted them and they refused a refund. I have opened a paypal dispute.
No these were brand new still in packaging. Only drove about 70 miles on them before this happened.
Old Apr 12, 2013 | 01:16 AM
artinist's Avatar
wow, never heard of anything like this. should have nothing to do with the lubrication of the bearing. the only thing that comes to mind that could cause this is if the upper nut was over tightened using a impact wrench.
Old Apr 12, 2013 | 03:38 AM
griceiv's Avatar
looks like an installation error in my opinion. Over torquing the nut will do that. especially when you're bending the strut against the maxed out bearing angularity trying to get an axle out (or back in) instead of just removing the strut completely. also sounds like the springs were massively preloaded to have one come shooting out when it snapped.
Old Apr 12, 2013 | 05:31 AM
Brent_si's Avatar
these were already assembled. The top nut was not touched. I was there during the installation. Only reason I didn't do it myself was because I thought there would be stupid issues with broken bolts. And the strut was not connected to the hub when I was replacing the axel. Any suspension is going to have tension on the spring. Get the facts by reading before you comment.
Old Apr 12, 2013 | 05:51 AM
wingless's Avatar
Yea, Get facts by reading.
Old Apr 12, 2013 | 06:59 AM
zenki-s13's Avatar
Got them from someone called 70after and the broke after about 70 miles. Their name says it all.
In all seriousness this sucks man. I hope the issue gets resolved for you.
-Taylor
Old Apr 12, 2013 | 07:27 AM
Brent_si's Avatar
I would think they should all be the same quality no matter who sells them. Ill keep updating with info as i get it.
Old Apr 14, 2013 | 08:57 AM
03whitegsr's Avatar
Incorrect. Coilovers generally aren't preloaded more then a thread or so. There shouldn't be more the a few pounds on those springs.
Even if it was heavily preloaded and being bent due to maxing out the spherical bearing, I don't think the shaft would break by hand force unless there was a material defect.
Old Apr 14, 2013 | 05:21 PM
Brent_si's Avatar
I made sure not to adjust the spring so it didn't put tension on it. I adjusted the bottom of the strut mount. Either way I don't think it should have broken.
Old Apr 16, 2013 | 06:23 PM
sofastsoreal's Avatar
way too crazy!
Old Apr 17, 2013 | 11:54 PM
EZ MONEY's Avatar
Interesting to know, I installed my D2's that I Daily Drive back in Nov and have about 6,000 miles on them.
Old Apr 18, 2013 | 12:19 AM
CN9Adaiski's Avatar
Wow thanks for posting this up.
I was considering a set too.
