Rota SVN-R 18x10 +30?????
Old May 13, 2013, 10:36 AM
MisUnderStood's Avatar
Whats up guys, I am in the market for some new wheels, I really want the 18x10 SVN-R titanium chrome's........ I see people running +20 but +20's where discontinued a while back they only offer these in +30, Id wanna go with a set up that can fit 265/35/18...... Does anyone know what i'd need to run these rims ?? Spacers in the rear or will they clear the brembo's?? What kind of spacer in the front?? Im not a fan of spacers..... Will +30's even look good or is it to high of an offset?? Could use some help getting my set-up as close to perfect, any input would be very appreciated.....
Old May 13, 2013, 12:15 PM
Received 1,384 Likes on 1,317 Posts
I cant answer all your questions but I ran your no.s through the calculator & think its doable for sure w/the following rear mods:
Rolled rears /Bumper bolt relocate / aggressive rear fender pull/ possible rear splash guard interference
(you noted the Stance thing so you might be running out of spec camber which will alleviate some rear fender issues)
As far as rear clearance, most wheels, especially low offsets like a +30 will clear the rear brakes. The fronts, I have no idea
Hopefully you get other ideas from the wide rim guys
Old May 14, 2013, 07:59 PM
BUMP, someone that has these wheels or had these wheels please chime innnn.....
Old May 14, 2013, 08:18 PM
jdmdc2r01's Avatar
I am running a 15mm spacer in the front, rears clear no spacer needed,
rear fender rolled, front rear fender liner slightly trimmed,
18x10 SVN +30 255/35 18 Advan AD08 (they run wide, like a 265/35 18)
hope that helps,
Old May 14, 2013, 08:56 PM
JJsevol's Avatar
You should ask these guys https://www.evolutionm.net/forums/ev...vo-thread.html
Old May 14, 2013, 09:05 PM
BrendanS's Avatar
Ran the +20 in that size, fit completely fine with no spacers needed. Probably one of the easiest wheels to fit. The +30 will need atleast a 10-12mm spacer to clear the fronts.
Old Jul 21, 2013, 01:12 PM
Evo9RS1789's Avatar
Heyo!
Did you ever end up running/buying this set up?
AntilagtunedMR
May 23, 2017 12:58 PM
WheelDude.com
186
Oct 13, 2015 08:37 PM
Vivid Racing
Apr 29, 2015 06:21 AM
jdmdc2r01
For Sale - Wheels / Tires
Feb 23, 2015 05:39 PM
knightey
Apr 27, 2010 11:43 AM
Quick Reply: Rota SVN-R 18x10 +30?????
