Aluminum hub-centric rings
Hey guys, running Rota's P45r's and I'm looking for aluminum hub-centric rings... get these plastic POS's off my car
My guy at tirerack was not confident matching a ring evo/rota combo so I'm looking for others experience/advice.
Don't make me pay a fortune for them
Thanks!
Thanks!
I have Enkei RPF1's, I run aluminum hubcentric rings because I've never had any luck with plastic ones.
I bought mine here:
http://www.tf-works.com/categories/W...centric-Rings/
I bought mine here:
The composite are easier to work with and don't seize up like the aluminum ones. Not to mention the composite is lighter and cheaper priced. Good ol eBay at $5 a set of four in any size you can imagine.
God knows how you can have issues with a ring you pop in the back of your wheel and never look at again. They don't fall out, they don't support anything, there just an alignment tool in addition to your more then likely acorn style lug nuts that also perform that very same task of helping you hold the wheel in place while you stumble to screw your lug nuts in place.
Oh well, good luck and enjoy.
Ahh ok, so your having issues with melting... I've never had any issues with the rings on my track wheels melting but in addition I do always make sure I get a composite ring and not just a traditional plastic one. I would imagine there's a large difference in melting points of the two.
Sounds like a fun thing to test some time in the future with some spare hub rings I have and a temperature gun. Interesting...
B) go measure your wheels if you want to be positive which ones to get
C) use the search function. https://www.evolutionm.net/forums/6275154-post5.html
A) they're 30 bucks. if they don't fit, skip lunch for a day...
B) There is enough information from plenty of others for me to inaccurately measure my wheels. Measuring round holes is actually pretty difficult without a bore tool.
C) I didn't start using forums yesterday I already searched and couldn't find my "guarantee"
I didn't ask for much, if its too much for you to bother you should just skip to the next thread.
Thanks to everyone else
I was looking into this a little while ago. If the wheel is lug-centric using the acorn-style lugs, what is the point of the hub-centric ring? I lift one side of the car at a time and tighten the lugs up in a star pattern several times over and then torque them down before the wheels hit the ground. I have never felt any oscillations or vibrations even up to ~140mph.
