Agency Power rear sway bar
I've been trying to find the 3 settings for the rear sway bar of Agency power. The advertisement is 27mm from the middle setting but I want to know what are the soft and hard setting are. Does it make 28mm on hard and 26mm on soft setting? Or at least what is the percentage (stiffer or softer) from the center hole (27mm)?
I sent Agency Power an email but there was no reply. I tried to call them but no one answers the phone.
I bought it used for a good deal. The car was good so far until I rearrange the rear differential clutch plates to factory spec. Now the car has a little too much throttle oversteer. I like it, but its a little too much oversteer and I need to control and stiffen the front a little bit.
I ned to know this so I would know what size front sway bar I should get.
By the way, I autocross and track the car at least once or twice a month and have 1 1/2 year of experience.
Finally modify how you are setting up for the corners, it sounds like you might be trailbraking and slightly over rotating. Brake more in a straight line. LMK if this helps
Malocas
Oct 24, 2013 06:11 PM
F0RSAKEN
29
Jan 21, 2012 10:05 PM
Beebo05
13
Jun 15, 2011 04:02 PM
mitsubishifreak
50
Feb 8, 2010 10:01 PM
rawkus
26
Oct 5, 2009 09:07 AM
