18 x 9.5 Rota grid question
Couldn't find much info on this so figured I'd post about it.. I have 18 x 9.5 rota grids and I want to fit them on my evo 8 mr with out any fender rolling.. What size tire can I run with out rubbing? I was told 255 or bigger and I have to roll them.. I have skunk 2 springs on the car also.. Thanks
I had the exact wheel on my last Evo. Fronts were no problem besides needing a 3mm spacer to safely clear the caliper. The rear I had to have my quarters rolled, pulled, and flared a good 1.5" and the car would still rub if you really tossed it into a corner. This was with reasonable camber in the rear; probably ~1.3'
I ran/run +20's alot of the time and I needed no spacers front or rear. Ran 245's (RE790's and RS3's which fit wider). Rears needed a decent roll. Front's need a bit.
I have on order a set of Option Lab S401's, basically TE37/Grid design, 18/9.5 +22. Also on order are 265/35/18 Hankook RS3's.
Should be about two weeks with how our weather has been around here, but I'll let you know what was/is needed to put them on.
FS[Mid-Atlantic]: Rota Grids 18x9.5 +20 Silver w/centercaps
keshav707
For Sale - Wheels / Tires
Oct 25, 2016 10:19 AM
FS[Northeast]: (NJ) Matte Black Rota Grid 18X9.5 +20 & TMPS
lippy1306
Apr 13, 2015 07:20 PM
