SuperPro DURO3741K Duroball spherical bearing for front control arm anyone?
#136
bumping for updates. Opinions? I may be looking to get rid of my PSRS ( I don't think a wider/*possibly* taller tire will fit with it) and going to a different bushing. I'm not really sure if I need any offset, but the DuraBall looks to have quite a bit less than my PSRS, but maybe enough to end up trimming bumper vs sideskirt.
I'd like to run a 275+ tire.. as much as I can fit on an 11" wheel. Things are getting pretty tight up front, is all I'm saying LOL.
#137
#138
The following 3 users liked this post by kyoo:
#145
#147
If you'd like something more robust there are the Powerflex adjustable bushings. They don't use any poly in them.
https://www.wunderladenracing.com/co...41578440327361
#149
https://stmtuned.com/products/kca469-evo-ct9a-front-control-arm-lower-inner-rear-bushings
#150
"It is effectively the same – yours has those holes as well, they’re simply filled in by a small ‘pour’ of 90A polyurethane – in the first of your two photos that is the piece that is separating – you could simply grab it and with a bit of force likely pull it out of the holes.
The holes themselves are there to take up any shrinkage during the curation process in the final bushing assembly. Initially these were then ‘filled’ by that small pour of additional poly. Initially tested to see if the assembly benefitted in anyway from filling those holes (it did not) it ended up being retained as the team apparently felt it made the assembly look better. At some stage they reversed course on that as it let us remove an unnecessary step from production that had no bearing on the performance of the finished product."
So the revised one may run into the same problem of the poly itself cracking. The part that separating from what it sounds like doesn't affect anything.
Am noting even though the warranty has expired on the bushing, SuperPro offered 50% off of the bushing if I wanted a replacement.
So the Whiteline and Superpro would be about the same price. I asked whiteline about it and they said the duro rating was 72. So Super pro is stiffer, which I don't mind, but which more durable is the question.
