Low Speed Popping - Check Your Power Steering Lines!
Old Jul 8, 2016, 07:05 PM
  #31
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
I have another question.... You paid someone to do this work, and now your car has a new noise... Why isn't the shop doing all this work?
Old Jul 8, 2016, 08:53 PM
  #32
kyoo's Avatar
he will be. we had limited time today before my track day so i just had a quick morning check up to make sure the car is good to go, then i have a saturday sunday track day, then it will go back to him and he's going to start with re-aligning the subframe...
just helping gather ideas
Old Jul 9, 2016, 08:19 AM
  #33
kyoo's Avatar
did a warm up lap on the track and got a ton of clicking/popping. not sure if it's exactly the same but it seems to be endlinks at this point?? stock endlinks, tanabe sustec fsb added
Old Jul 10, 2016, 10:37 PM
  #34
TheBoz's Avatar
Did they grease the swaybar?
Old Jul 11, 2016, 06:17 AM
  #35
kyoo's Avatar
yes they did - I got some major popping/clicking on the track though... I'm thinking it's the endlinks
Old Jul 21, 2016, 09:08 AM
  #36
kyoo's Avatar
well, had the shop realign the subframe, redo the alignment, loosen and tighten the bolts on the endlinks, and grease the fsb bushing - the popping noise is still as present as ever.
going to undo the endlinks tonight and go for a drive and see if any noise comes about... any other ideas? I've ruled out most of the common noises..
Old Jul 21, 2016, 05:51 PM
  #37
kyoo's Avatar
all right... not the endlinks, drove the car with the fsb uninstalled.. we're stumped.... any ideas from anyone??
shop said when they did the work they didn't unmount the struts from the top - he said he wired them up and out of the way when the front was apart.
could a cv joint have gone bad during the process?
Old Jul 22, 2016, 06:54 AM
  #38
kyoo's Avatar
noise is driving me nuts. I'm not sure at this point what to do without starting to replace everything.
from internet research, here's a list of things I'd like to check:
- cv joints
- ball joint
- rear motor mount
- tie rod ends
- lower control arm to subframe bolts
- control arm bolts
- wheel bearings
I'll take a video of the car revving in neutral with the hood up to take a video of the engine movement to see if it's ok, too much, etc. and go from there I guess.
Old Jul 22, 2016, 04:37 PM
  #39
kyoo's Avatar
more pronounced:
Old Jul 25, 2016, 08:35 AM
  #40
kyoo's Avatar
bump
Old Jul 25, 2016, 10:29 AM
  #41
kyoo's Avatar
bump
Old Jul 25, 2016, 07:44 PM
  #42
kyoo's Avatar
bump
Old Jul 25, 2016, 10:28 PM
  #43
This has me baffled. Especially not being there. Random NVH stuff is about impossible over the Internet
Old Jul 26, 2016, 05:31 AM
  #44
kyoo's Avatar
does it still sounds like rear mm
Old Jul 26, 2016, 09:05 AM
  #45
I don't know what it sounds like. The rear trans mount was simply a suggestion for something to be sure to check. Hopefully the mechanic checked it while they had the subframe loose the second time.
Quick Reply: Low Speed Popping - Check Your Power Steering Lines!
