What size tires do you guys use with your lowered evo
Thinking about getting some swift mach sport springs. I already have some bilstein struts on it. I'm on stock height and i still scrape. What size tires/rims you guys run on yours
Current hight:
Current hight:
Offset is probably too low. These are 265/35r18's on 18x9.5 +35 wheels. Rear fenders fully rolled, 10mm front spacer. On coilovers.
i'll double check the sizes when i get off work. No work besides struts on the front and rear. Mostly the rear rubs.
Joe to the rescue! Lemme take a stab at this and then you can run it through your calc. Those wheels look to be Rota G-Force wheels. Given your tire size we know the rim is 18" but the offset and width are still up in the air. I just popped on their website and found this chart: http://www.rotawheels.com/wheel.php?id=27
By process of elimination the only viable option is 18x9 +30. Now I did make a few assumptions in that those are indeed Rota G-Force wheels, that those are the only sizes they ever offered and lastly that the OP isnt using some sort of spacer adapter. Id say I feel pretty comfortable with that answer nonetheless.
And given that I'd say the rears could probably use a simple roll and you should be good to go but other things such as camber and ride height must be taken into account and that'll dictate what else is needed.
Doctorbird876
Aug 4, 2013 05:00 PM
mitsuevodriver
Apr 8, 2010 04:45 PM
evovin
Jul 19, 2009 08:37 AM
badboybr09
18
May 7, 2007 10:26 AM
