Lug nuts for stock enkei's
Looking for the correct lug nuts that will fit stock enkei's. I'm getting them powdercoated and am looking for a set of black lug nuts. I hear this can be a bit more complicated.
Can someone point me in the right direction?
Will any 12 x 1.50 lug nut work?
Regards
Regards
MinusPrevious (Apr 5, 2017)
The following 2 users liked this post by DontStopMe:
MinusPrevious (Apr 10, 2017),
schmeevo (Apr 5, 2017)
I literally paid close to 4 times more TODAY for an OEM set, and these are much nicer!
The stock Enkei wheels look really good on a kouki
I know this is kind of an old thread, but I'd rather build on the foundation already laid..
Is the shank of the factory lug 18.5mm wide or am I missing reading their measurements in the ebay ad?
I put the stock Enkeis on my 240, but I only have conical style lugs to go on them so I'm not going to drive on them. I'd like to get another set of M12x1.25mm mag seat style but I think that the shank (the part that fits into the wheel when the lug is tight) needs to fit into the lug hole of the wheel pretty close. There's some I found on eBay that are 18mm wide but it seems the factory style is 18.5mm... will that .5mm make that much difference or am I pretty safe to get those?
I've also considered changing the lug studs to an M12x1.5mm like the Evo but the only ones I can find that fit the 240 are ARP aftermarket and they are 60mm long and wont work with the stock Lug nuts... Seems like every time I think I have this problem solved I hit another wall.
@cerevo
Heres what most guys do for long studs on the EvO and want to run the stockers. I see that the 240 has a thinner stud but hope this helps
See here: https://www.amazon.com/Nuts-Toyota-L.../dp/B015AMTGCK
https://www.amazon.com/gp/aw/d/B07FW768NJ/ref=sspa_mw_detail_6?ie=UTF8&psc=1
So I think these might be my ticket. Best of all worlds in that I can use the Evo wheels, with the factory lug stud on the 240, and they're only $40 and 2 day shipping (which I can get these wheels on the car and tested to make sure there's no rubbing etc before my trip to the Tail of the Dragon! )
Thanks!
I don't have any insight for the eclipse, but just a check in. I got my m12x1.25 black lug nuts and they fit the Evo wheel perfectly and look great on the car! I had to use the Ole 19mm 12 point socket and hammer trick to get my lock nuts off the Evo since this is the second time I've lost the key to them I'll never use another set of locking lugs like that... I've never lost a key to any other set of lug nuts For some reason that one is just hard to remember to grab and put back in the car I guess.
Hirudin
Nov 5, 2011 07:41 PM
injentech42
For Sale - Wheels / Tires
12
Sep 15, 2009 03:27 PM
goevox
Nov 29, 2008 12:17 PM
4-G-rim
Feb 17, 2007 06:12 PM
