18x9.5 +22 Enkei rs05r Fitment
Old Apr 4, 2018, 03:30 PM
Marcin43's Avatar
I am looking to buy 18x9.5 +22 Enkei rs05rr for evo 9. I have stock suspension & don't have my fenders rolled. I was wondering if anyone has this fitment that can help guide me with what might have to be done. I've read that its better to run 8.5 but the +35 offset is really close to a stock wheel look. Thanks in advance
Old Apr 5, 2018, 10:27 AM
evo9_mike's Avatar
I have 17x9.5 +20 on my 9. I had to roll my rears to stop the tires from rubbing when I hit bumps. I'm on coil overs, lowered, as well to give you an idea.
Marcin43 (May 11, 2018)
Old Apr 5, 2018, 03:33 PM
evo9_mike's Avatar
Old Apr 5, 2018, 04:51 PM
Toekneeng's Avatar
Not sure what look you're going for or if you plan to lower it, but at stock height you shouldn't need to do anything.
255/35R18 is the standard size tire for that wheel size.
If you do lower it, a rear roll is required.
Old Apr 7, 2018, 03:53 PM
Raptord's Avatar
I'm running 18x9.5 +27 and needed a roll+pull. I suspect you might need a roll even at stock suspension height.
Old Apr 10, 2018, 04:22 AM
EVOFans's Avatar
18x9.5+35 and 255/35/18 you *might* be able to get away with no rolling but it is going to be close
Old May 5, 2018, 02:30 PM
deafspill's Avatar
Heres mine that I got last year. I was lowered on swift spec R’s at the time with stock shocks. Rear fenders were cut but the fronts stayed the same. If youre gonna be on stock springs and shocks you should clear it no prob.
Old May 11, 2018, 11:02 AM
Marcin43's Avatar
Thanks for the help !
I purchased the rims and they are just rubbing in the back when i hit a bump. Will probably do coilovers.
Old May 11, 2018, 11:05 AM
Marcin43's Avatar
Photo of rims on the car
Old May 11, 2018, 11:09 AM
evo9_mike's Avatar
you'll probably just need a roll
Old May 11, 2018, 11:38 AM
Received 1,384 Likes on 1,317 Posts
Trying to confirm what the specs are: 18x9.5 +22 running a 255/35 tire?
To get this assembly to clear correctly you will need more than a roll. Rear fender pull & bumper bolt is needed. Try this: disconnect & remove the rear strut. Disconnect the rear sway (one side only). Jack up the rear tire into the well & see if you have clearance (see example pics below)
There is no way you will have clearance w/just a roll. If you plan on running rear passengers & drive the EvO hard, you will need the proper, "No Rub" clearance
Old May 11, 2018, 12:26 PM
deafspill's Avatar
badass! clean evo! congrats on the purchase!
Marcin43 (May 15, 2018)
Old May 11, 2018, 12:33 PM
deafspill's Avatar
if in a budget, Fortune 500 with Swift springs will work. the other popular choice is the ohlins dfv. though they are on the pricey side. good luck!
Old Jun 4, 2018, 09:13 AM
jwalleg's Avatar
wow that looks damn good
illvolution
Sep 24, 2012 02:22 PM
Touge Factory
54
Sep 1, 2009 10:11 PM
Kami Speed
Evo 'For Sale' Wheels / Tires
21
Oct 3, 2008 07:42 AM
SOLO2M3
Jan 4, 2008 05:57 PM
machron1
Gruppe-S Engineering - California
23
Oct 21, 2006 09:16 AM
Quick Reply: 18x9.5 +22 Enkei rs05r Fitment
