Question about replacing damaged new tire; replace all 4 or just the one
I understand that when you need to replace a tire on our cars, you need to replace all 4. Well, I just got 4 new tires on within the past 5 months, and have only driven *maybe* 500 miles, if that, on them. One was recently damaged with a knife and needs to be replaced. My question is this: Do ALL 4 really need to be replace with such low miles? Or will one suffice? I'm not trying to destroy my drivetrain here, but if I can avoid spending another 600+ on tires I'd rather do that and just replace one or the rear two.
Any suggestions here would be really appreciated.
Im sure that would be OK. I would measure the circumference of the newly mounted tire vs the 500 tire & see how close they are
Cant imagine that 500 miles would affect the circumference that much (tire shaving may have to be done if they are not close)
(let me see if i can find the allowable variance allowed between circumferences)
Heres a quote from Tire RackReplacing Pairs of Tires or Individual Tires
There are several suggestions that have been offered to drivers who are replacing pairs or individual tires on their four-wheel drive and all-wheel drive vehicles. Some vehicle manufacturers recommend that all tires maintain the same rolling radius and circumference, while others suggest that all tire circumferences remain within 1/4- to 1/2-inch of each other. Other vehicle manufacturers recommend that all four tires remain within 2/32-, 3/32- or 4/32-inch of each other, or within 30% of each other in relative remaining tread depth.
Welcome2GoodBur (Jun 28, 2018)
I was hoping you'd chime in Minus, you seem to be the GURU here for this stuff. I'll measure it all when I get it back.
Second question then, due to an order mixup, we were sent a ExtremeContact DWs 6 rather than the EextremeContact Sport that are already on there. These are obviously two very different tread patterns, but for a temporary fix, since both models are exact same height, width, size etc, will this be safe to run until I get the sport re-ordered, or best to not?
MinusPrevious (Jun 28, 2018)
Joe
Tire Rack can pre-shave tires to desired tread depth so that your new tire matches the rest. That's what I did for mine several years ago and I had absolutely no issues. Get a tread-depth meter and check what your old tires are at, and just have them shave the new one to match.
With only 500 miles they'll be fine. As long as you get an identical tire (brand, model, and size), the allowablw tread depth difference is 4/32" IIRC.
boostislife
12
Nov 8, 2016 03:03 PM
eville_stu
13
Jan 20, 2011 05:07 AM
EVO MR FU
Mar 25, 2005 08:58 AM
AbusiveWombat
Feb 17, 2004 11:16 AM
TammieNAndi
Oct 26, 2003 09:41 PM
