looking to buy a tool for bleeding brakes & flushing brake fluid (not just for evos)
Biggiesacks (Sep 23, 2018)
I was gonna put a caveat like practically or almost no chance, but i figure if your that incompetent (or high/distracted ) that you still screw up and let the motive and the master go dry you probably should just not be doing the job. Clearly though that was a mistake so I'll go ahead and clarify my statement.
We knew what ya meant. If we had to add exceptions to all our posts for all the "what-ifs" and common-sense stuff, we'd all be typing novels. I.E. If you say you are using a compressor to air up your tires, we all assume you are gonna stop before you blow the tire off the wheel.
All you need to do is purchase a set of speed bleeders they have a check valve in them and its now a one man job they are like $20 a set
https://www.lancershop.com/customer/...productid=1771
The Russel speed bleeders ended up working out the best for me, but they are more of a caliper mod then a tool you can use on other cars. They are sold in sets of 2 so you need 4 sets. $20 bucks a set is kinda over priced, I got them for 12 bucks a set delivered from amazon.
