what should I pick for coil overs?
Trying to decide between BC racing BR series and Tein Flex Z's. I've never bought coil overs before so I have no idea which to choose. Was wanting to get the BC's with 7/8 front/rear springs, what do you guys think for street/late night mountain fun? The Teins look like they come in 8/7 front/rear. Isn't stiffer front spring rate going to cause under steer? I suppose they come stiffer in the front due to the front of the car being heavier. Will I even notice any understeer at speeds in corners you think with a difference of 1kg/mm in the springs? Thanks gents.
Most of our suspension guys here on the boards will tell you pick neither. I use Fortune Auto but a lot of our experienced members
prefer Ohlins
Regarding spring rates, here is a laymen's video on why the EvO uses a heavier rear spring than the front. Its worth watching if youre not familar w/the term "motion ratio"
prefer Ohlins
Yeah Ohlins are out of the budget. Definitely considering the fortune 500s now though. I understand motion ratio and why the spring rate should generally be stiffer in the rear considering evos are usually 1:1 front and somewhere around .65-.8 rear in terms of ratio if I"m not mistaken. What I was confused by is why the Teins come stock with 1kg/mm softer rear springs.
How do you like the fortunes? What spring rate do you run and how do you drive it?
Ohlins can be had for less than $2k from Performance Shock. Well worth it to save up the extra $500 for them.
feel free to link cause I can't find that, every I site I have found ohlins on for an evo 4 are 2.5k roughly in EUROS. I'm in Canada so that is super pricey for me. I'm reading a lot of good things about the fortune 500s, the BC's and Teins were a lot more mixed.
I just found them but they don't seem to have any for CP/CN9A, and as far as I know 8/9 aren't compatible on the 4, correct me if I'm wrong about that though. Also the prices are listed as 2375 with which google I find is 3076 CAD. The fortune 500s will run me 1650CAD. For someone who isn't really wanting to spend all the extra money, are they REALLY worth it? What specifically is so much better about the ohlins? Keep in mind, I'm not really tracking the car right now. Mainly street use and "fun" lets call it late at night on the mountain roads here in the great mountainous region. I'm not really looking to lower it either, although I may ever so slightly, but I'm mainly just after stiffer springs. Worth it just for that?
If cheap is what you want it seems some really like the FA500s, but as other have said I couldnt recommend anything less than the Ohlins as an entry into coilovers. Less than that, and I would stick with Bilsteins HDs with a good spring. Though Ive heard thats even tough now that GTWorks springs arent made anymore (no you cant have my spare set :P)
The attraction of the Ohlins is that they ride so much better. The thing that makes the ride better (the DFV valve) also enhances their track performance.
You should email PSi for a quote. The price drops quite a bit. That way you know the actual $ figure you're looking at.
As far as having a different chassis, I'm not sure if Ohlins makes stuff for the older ones. If they did it may not be available here since the cars didn't come here.
Hey!
I personally love Fortune Auto for a great quality product at an affordable price. If you are using a car as a serious performance dedicated vehicle the Ohlins are AMAZING to say the least fantastic ride quality and huge handling gains to be had.
Let me know I will get you a great deal!
Leo
Leo
