StopTech Brakes Review
Finally got around to buying the rear kit to match the front StopTech kit I bought in 2012 (wow time flys!)
Love the fit and finish of the kits, not one problem with the front kit after more than 80k miles (this is my daily/commuter car) The paint on my front kit still looks brand new, no fading or blistering like the OEM Brembos. Installation is a snap, I did have to grind the caliper mounting tabs as mentioned in the installation instructions, nothing significant, basically cleaning up the casting flash.
I’ve got the Sport pads on front/rear and they work well for street duty, initial bite is a bit on the lazy side, but once they heat up just a tad, oh-boy LOTS of stopping power. The one gripe I do have with the Sport pads is lots of brake dust, I am thinking about trying the Street pads just to see if it gets any better.
Front/Rear Bias and Modulation is right on with no unexpected drama. It takes a lot of abuse to get them hot enough to fade – Yes I can overheat them, but they are head and shoulders better than the Brembos. Overall I give this StopTech setup a thumbs up.
What I bought:
Front Kit: 83.622.6700.71 (355 Rotors and ST-60 Calipers)
Rear Kit: 83.622.0043.71 (328 Rotors and ST-40 Calipers)
Hope this helps anyone looking at the StopTech kits.
John-
What I bought:
John-
I want to say I also did the install this weekend for the front Sport pads and took the evo out for a little break in with the pads. I was coming from the Hawk 5.0s and I was really impressed with them. After a few runs with the Stoptech Sport pads I can say I like them too. I don't have the full break down on temp scale between both pads but after a recent inspection of the front pads ( pics below ) I noticed it was time to replace them. You can't beat the price of the Stoptech pads either. The Hawks were almost double the price. I won't know the wear life of the Stoptechs but I like the feel so far. For those of you needing help doing the pad install there is a great "How To or DIY" on the site which I used. I did not find the Copper Anti Seize most would recommend locally so I used the Permatex Extreme Brake Lube which claims to be Effective from -50°F to 3000°F (-46°C to 1649°C). After the install and some bedding I did not have any unpleasant noise or squeal so many people speak of after doing the brakes.
Hey Soso
No, 18's are required. Here are the details from MAP if interested
https://www.maperformance.com/produc...83-622-6700-71
