Evo Tires, Wheels, Brakes & Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Sponsored by:
Sponsored by:
Replacing worn bushings OEM, hard rubber, poly?!?!
Old Jan 18, 2019, 02:39 PM
SoSoEVO's Avatar
Recieved 29 Likes on 27 Posts
Hi Evom I'm currently getting all of the maintenance done on my evo and I would like some input on replacing bushings. My evo isn't my DD but it's still a street car so a little added NVH isn't going to bother me if I go with a stiffer option. I will be tracking my car and would like better performance/ longevity/ least maintenance (ie. grease or oiling) as I know replacing bushing is a not the funnest job so I only want to do it once for a long time. I've heard poly bushing can be noisy and warp/ deform giving slop but I haven't actually seen factual data from people that run their cars hard. Hard rubber bushings like "Hard Race or Cusco" are also on my radar, a lot of Honda guys run the Hard Race but they don't give very detailed reviews. I did stumble across a few various threads during my research saying the steel liners corrode very quickly and separate from the actual rubber not sure if that's true or not and I guess there is more stiction which actually hurts suspension movement?
OEM = another 100k+ miles between changes, no added performance (well maybe a lil since I'm replacing worn bushings)
Hard Rubber = more stiction, better performance than oem, unknown longevity w track usage
Poly = good performance, possibly deformation, needs to be lubed or can get noisy
Solid mounts = best performance, for race cars haha
I have Energy Suspension poly bushings in the LCA's of my off road 4Runner and they have taken a beating for the past year with no deformation (the LCA bushings hold the eccentric bolts to adjust toe angles, so if they were deformed I'd know since my alignment would be off). I'm leaning more towards the hard rubber bushings as a middle ground but I'd still like to get some input from people who have tried any of the combinations that run their cars pretty hard.
Thanks!
SoSoEVO is offline
Old Jan 18, 2019, 03:53 PM
EvoM Super Moderator
Recieved 756 Likes on 721 Posts
Hey SoSo
Im no expert, but im running a full set of Whiteline bushes front / rear
From what ive seen on the boards, there are many who have used the ES bushes w/no issues. They are quality pieces for sure, IMO. I just happened to go w/the WL brand
You certainly dont need solid bushes.
I think going w/the the PU set is your best bet for performance / longevity
Joe
MinusPrevious is offline
Old Jan 18, 2019, 04:44 PM
ayoustin's Avatar
Recieved 92 Likes on 83 Posts
The poly stuff holds onto the lube pretty well and if you ever do have to lube em it's not that hard. I'd say the poly stuff would probably last at least as long as the OE stuff seeing as you're in CA and don't have to deal with lots of corrosion.
ayoustin is offline
Old Jan 19, 2019, 09:46 AM
xRoguex's Avatar
Recieved 7 Likes on 6 Posts
Get the Energy Suspension Master kit in black - which is impregnated with graphite and does not squeak.. ever... Apply the assembly lube everywhere.. and your set.
I have over 50k between 2 evos on them and they are amazing.
xRoguex is offline
Old Jan 20, 2019, 10:18 AM
GSX_TO_EVO's Avatar
Recieved 19 Likes on 17 Posts
http://www.esmrace.com/product-p/evo89.esmmkit.htm
This is what I went with. They will wear out, and youíll have so swap spherical bearings every now and then, but they just pop out with a c clip. Very nice pieces. Car isnít together yet, but Iíll have a review after itís on the road.
GSX_TO_EVO is offline
Old Jan 20, 2019, 04:21 PM
kaj
kaj's Avatar
Recieved 278 Likes on 265 Posts
My entire car is on poly bushings. I haven't noticed any difference in NVH, but I may not be as sensitive to it, since I don't daily the car. No weird noises or anything in three years, but I've also only put 5,000 miles on it. If not being competitive/etc with the car and you can replace with OEM, that's the way I'd go.
kaj is offline
Old Jan 22, 2019, 09:04 AM
SoSoEVO's Avatar
Awesome thanks guys! The master ES kit is priced really well...ok I'll go with poly then since they have performed well for you guys. Another question my ball joints need to be replaced also, they're weeping grease. Is the general consensus here to just get the Whiteline roll center correction ball joints? I'm going to be stock height for a bit until I find some racecomp lowering springs and some used MR billy's, do you think there would be any negative effects installing them at stock height?
Edit: Per Whiteline's info roll center correction balljoints should be used on lowered vehicles.
SoSoEVO is offline
Old Jan 22, 2019, 10:31 AM
kaj
kaj's Avatar
Whiteline's kit barely makes a difference. I can't imagine it would harm anything to use them.
kaj is offline
Old Jan 22, 2019, 10:34 AM
Yeah, if youre lowered running the WL correction kit will help some (i run it). Its not a real game changer until you change out the hubs to correct the lower A-arm angles
Hub suppliers that do that are SSB or Wisefab
The roll center kit no.is KCA-395 (please double check)
Old Jan 23, 2019, 12:59 PM
SoSoEVO's Avatar
SoSoEVO is offline
Old Jan 29, 2019, 04:02 PM
Fox_IX's Avatar
Recieved 13 Likes on 12 Posts
I've had the best luck with coating the PU bushings in copper anti-seize rather than the included grease. No squeaks or weird noises after that.
Fox_IX is offline
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
