Brake Problem
Brake Problem
Ok. I posted a topic last week about needing help with my brake pad install and no one responded (before I had to get started) So, I did the job and now the new pads squeal like a stuck pig. Then I re-did the job and they still squeal. I had the rotors (front) turned and installed the Ferodo DS2500 pads the same way Ive installed pads in the past. What gives?
I used a generous amount of anti-squeal, both times. The first time I squirted the antisqueal goop between the pad and shim and on top of the shim, then installed. I thought maybe the stuff needed to dry before I installed them, so I removed them all, scraped the stuff off and tried again...this time letting the goop dry before I installed them and only putting the stuff on the outside of the shim/pad and not between. Still squealing. Any ideas?
Did you reuse the "sticky" shim from the stock brake pads?
There should be the "sticky" shim on the back of the brake pad in addition to the floating shim. Also, don't forget to use the anti-squeal on the top of the brake pad where the copper spring touches the pad.
Originally Posted by mayhem
Hmmm...I get occasional squeel with the 2500s but hardly enough to complain about. Are the pins in all the way? Maybe try a different anti-squeel compound.
Spray down the shims with brake cleaner and get all the funk off of them. Do the same with the back of the pads. You might also want to try cleaning the caliper pistons. I never put the compound between the pistons and the shim but it looks like Mitsu did at the factory. Goo gets built up on the pistons too.
Lastly, I use the compound very liberally
update
Ok. bottom line: You need the sticky shims.(the shims glued to the stock pads) Nothing I tried makes the squealing go away until I put the shims back on. I will find out if you can get this shim material from a parts store...More to follow.
xbox4414
15
Sep 22, 2008 09:15 PM
mike127
Aug 25, 2008 07:43 PM
QwikEVO
Aug 8, 2006 04:44 PM
