-   Evo Tires / Wheels / Brakes / Suspension (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension-23/)
-   -   RA-1's Noisy? (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension/133180-ra-1s-noisy.html)
taylor Apr 12, 2005 09:37 AM
RA-1's Noisy?
I have a set of ra-1's w/ 5000 miles on them and they are pretty worn. I'm just curious how much noise other people are hearing with these tires. Mine sound like a moderately loud high pitch hum at steady speed(60mph) changing to a lower pitch "ummm" sound below 20 mph. They have slightly more inner edge ware, if it matters. The noise does not bother me, I just want to make sure it's not my t-case going south.
BTW, the sound does not get louder with speed, it just changes tone. If anything it dimminishes above 80mph, and is there regardless of gear/rpm. This is what is leading me to believe it's the tires and not something mechanical.
number 8 Apr 12, 2005 09:41 AM
I've got RA's in about the same condition, and I don't notice noise like that.
evo81 Apr 12, 2005 11:07 AM
not loud at all.
kekek Apr 12, 2005 02:48 PM
Mine do make a light "hum" if you want to call it that (full tread). WAY way quieter than my worn Advans.
taylor Apr 12, 2005 06:09 PM
thanks for the replys. To give you some idea of the noise level, with the stock radio, I have to turn the volume up to 26 to drown out the noise.
also, i forgot to mention that braking at low speeds changes the depth of the "ummm" sound as well, and also causes a very slight vibration.
BTW, could a sound like this be an indication of a bad transfer case? (I'm at 17000 miles with no launches FWIW)
