-   Evo Tires / Wheels / Brakes / Suspension (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension-23/)
-   -   17 x 10's : What offset? (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension/204674-17-x-10s-what-offset.html)
dr.mr Jun 5, 2006 06:57 AM
Does any one know what offset would work best on the
17 x 10 5 Zigen FNO1R-C rims? I can get 25mm or 35mm.
I am currently running 17 x 9's with the 35mm offset with
5mm spacers up front.
Tires are 275/40-17 Kumho 710's.
scorke Jun 5, 2006 07:02 AM
Any reason for such a wide rim? Are you looking to just stretch the 275's more?
Scorke
dr.mr Jun 5, 2006 07:09 AM
Scorke
Yeah my 9" rim is the bare minimum (range is 9"-11" for the 275).
Robi-spec told me that I was choking my tires and not benefiting
with a full patch of rubber on the ground.
South Side Evo Jun 5, 2006 11:01 AM
I know 17x9.5 will fit with +25 up front and +35 in the rear, but you will need to roll your fenders.
South Side Evo Jun 5, 2006 11:02 AM
https://www.evolutionm.net/forums/sh...ghlight=17x9.5
scorke Jun 5, 2006 11:13 AM
South Side Evo did you even read the post?
Dr.Mr- Gotcha, I was always under the impression that a 275 on a 9.5inch rim was just about optimal good to know, and I suppose it varies depending on sidewall as well, what does robi run on the Buschur car out of curiosity if you know?
Scorke
dr.mr Jun 5, 2006 11:45 AM
Scorke
The Buschur Time-Attack car is running 305/30 - 18 Hoosiers.
scorke Jun 5, 2006 11:47 AM
Yeah what width, I thought they were 9.5s or so? Sorry what I was getting at was that I thought (at least for road course shenanigans) that a 9.5 inch rim with a 275 in 35/40 profile was plenty wide enough.
Scorke
value Jun 5, 2006 11:51 AM
Too bad no 5 Zigen FNO1R-C rims 18x9.5 :crap:
South Side Evo Jun 7, 2006 04:31 PM
Scorke
Yes, I read the post, and I'm stating 10's will not fit (without serious modification)but you can get 9.5 to fit (with just fender rolling).
dr.mr Jun 7, 2006 05:10 PM
Well, I autcross now with 17 x 9's with 275's with only 5mm spacers up front
and no fenders rolled.
I'm getting the 17 x 10's in a couple days. I'll let you all know what I have to
do to get them on.
South Side Evo Jun 7, 2006 05:17 PM
do to get them on.
I'm definitely curious to know if 10's will fit with 275.
JohnBradley Jun 7, 2006 07:04 PM
So you have measured this out have you? 9.5 et 25 is further out than a 10 et 35. They will fit in the front with a little rubbing, the rear requires rolling and a little bit of a pull. I am doing this next year for track wheels and keep 275-35-18 and split offset 18x9.5 (et 25 front, 35 rear) for street.
smack_evo Jun 7, 2006 07:19 PM
^^^ the rear work fine awith just a roll as long as you roll the lip flat. i run 5zigen 18x9.5 +35 with 275/35/18 ra-1's. no rubbing fully loaded up at the bottom of the corkscrew at laguna or the cyclone at t-hill.
the thing you have to watch out for when going past 9" is that inner suspension parts start coming into play. you go too far inboard in the rear and trailing arm clearance becomes an issue. 17's have more of an issue. going to larger diameter rim actually helps with this.
up front though, you start hitting springs and perches on coilovers. i had to run 8" spring lengths
so the perches were up high enough to clear the tire. you can run less offset or spacers to help with this but then fender clearance becomes an issue.
it's quite a little dance to get this all working well together :)
it definitely helps to get some advice from someone like robi(or some of these other guys who have set up real cars). he's gone through quite a few iterations of these combinations and would probably have some go info on what to look for and stay away from.
hope it helps
dr.mr Jun 8, 2006 05:18 AM
Good info smack evo. I'm using 17's because the way I go through tires, it's
more affordable!
My current 17 x 9 has 35mm offset and the new 17 x 10 will have 25mm offset.
So that should help with fitment... we'll see.
