18x9.5 Wheels with Wide Fenders
I'm getting some streetconcept c2 fenders, or chargespeed replicas put as right now and I also wanted to get a set of the 5zigen fno1rc 18x9.5 wheels. I'm looking to get the one with a deep dish but im not sure if the offset is +22 or +35 but I see that z1 only sell +35. I also want to know if I will have rubbing issues with the extra 10mm that the fenders give and what size tire should I run? :confused: ps I'm also on Hotchkis Springs.
You should go with a 18x10. If you're going with the 18x9.5 you should be able to run a +10 or less!
18x9.5 +15 fits behind the STOCK fenders when rolled and stretched tires. |
Will that cause any other problems such as it rubbing against the body causing me not being able to turn? Might be a dumb question but I know stock fenders are aluminium and can be rolled, but can you roll fiberglass fenders???
also I dont think they make the fn01rcs in anything larger than 18x9.5 and I really like the look of this rim. Im planning on getting bronze bc it looks best with yellow. So mainly I need to know if I should get +22 or +35 offset and which tire runs best with my extra 10mms that my fenders allow, to not rub or cause any problems.
