extended wheel studs-q's and source
i ve been thinking of going this route
and then found that evo studs are 12x1.5 same as honda which i happen to have a set of honda studs also if i remove the fronts is the area/hole that they get pressed (the knurled area) into the same size as honda/acura? \i find you can hammer them out and then use nuts to kinda press them in again does that apply for front and rear or should i just get a shop to press them in properly---removal of the hub where are you getting your ext wheel studs also |
H&R 15mm spacers come w/ extended studs.
You can also look into KICS wheel spacers. These come extended studs onto the spacers already. It makes installation a breeze. I use both on my current setup (18x9.5 +27mm NT03M) |
hey does anyone know a price on the spacers and extended studs and also special lug nuts will be needed also ??
Check out ARP wheel studs as well. They're supposed to be very strong. I used the Project Kics extended wheel studs and broke 4 of them at the track.
| All times are GMT -7. The time now is 08:50 PM. |
