Problem with 255/40/18's
Hi,
I just installed Advan RGII GTR face with 255/40/18 RT615. I am have rubbing issues from rear wheels when going over some bumps or taking sharp corner also some from front wheels when turning the wheels . I have a stock hight 06 EVO MR. I thought that running 255 would be fine with stock height. What are my options right now? rolling the fender? how much does it cost to roll the fender generally? thanks |
I believe that 40 serie tires are a bit wider and thicker then the 35 serie. I have the same rims with 255/35/18 S03 tires on tein coilvers without rubbing even with the lowest setting. My car is lowered 1.5 finger gap all around.
Originally Posted by ABN EVO
(Post 4186986)
255-40-18 is 26" tall
235-45-17 is 25.4" tall. 255-40-17 is 25" tall. The math speaks for itself I think. |
Why do people think that you can run the same aspect ratio tire when moving up to 18" wheels! Think about it, 255/40/17 tires are ~255mm wide and the sidewall is ~40% of that, making them ~102mm, or about 4.02", tall. Double that (8.04") then add 17" for the wheel diameter and you get ~25.04" overall diameter (most 255/40/17 tires range from 25"-25.2" overall diameter, which is less than the stock 25.3" advans...) Perfect, fits like stock, etc...
Now, do that same math, but add another inch for the 18" wheel diameter, and you are looking at a tire that is ~26" tall! Gee, why doesn't my tire fit when it's an inch taller than stock? Hmmmmm can't imagine... Anyway, you should have done some research because you bought the wrong size of tire... If you would have gotten 255/35/18's, you would have been fine, or at least a lot better off... |
Thanks all for your help.
| All times are GMT -7. The time now is 09:15 PM. |
