KW V3 vs Zeal Function Xs
I'm looking for good coilovers, mainly for street but with an occasional track day and auto-x. I've read great things about the KW's, but I would need to get camber plates, so that puts the price right at the same as the Zeal Xs.
Would Cusco front plates work well with the KW's? I like that the KW's are dual adjustable, but to be honest I probably wouldn't adjust them too much. But at the same time I want something that is great quality, so I don't really want any of the lower end clone coilovers, aka Megan, Helix, Stance etc I actually like the ride of my Tanable GF210s on stock struts/shocks, lol, but I'm getting Work 18x9.5" 20mm ET CR Kai's, so I need to have the ability to add some negative camber in the front and dial in the ride height as well. And I know that sooner or later the stock struts will blow withe GF210's. Thoughts? Another option is the Cusco Zero2R. Anyone? |
you can use stock top-hats with KWs so no need for camber plates and you can still set camber to -3. Unless you want to make changes from street to track, than its a different story. Cusco plates work with KWs.
Contact Robispec if you need more info about KWs
Originally Posted by EvilTechnology
(Post 4679432)
thanks for the info{thumbup}
