Front Suspension Clunk Noise
Under hard braking my front suspension makes a loud clunk. Then when I accelerate afterwards it makes the same clunk again. If I brake hard, then jack the car up it will also make the clunking noise when the tires are almost off the ground. I have gone over the front suspension multiple times and I cannot find the cause. I know people have had an issue with a front end clunking noise, but I cannot find a definitive answer to what the cause is or how to fix it. My car has 100k miles on it. Thanks.
A. Check ball joints,
B. Check sway bar linkage( is it secured, is it tightened down) c. Check lower front control arms( are the bushings worn away, is it tighetened down) d. Check the calipers are they properly tightened. Did you hit a huge pot hole, or run a curb??? If so you may want to pull off some of the main bolts to the suspension and check for thread damage. I say this because I hit a damn sidewalk w/ the evo. The bolt holding the ball joint to the knuckle was stripped. |
my axles where broken when i had that sound comming from the front. after i changed the axles it was still making that noise and my mechanic found the prob in my transfer case. it was my differential. it was destroyed after a weekend at the speedway doing 1/4 miles passes. hope this helps . {thumbup}
Originally Posted by LVmevo
(Post 7071234)
Bump, anyone?
The same here but my car has been doing this since the day it left the showroom. Now, 60k later, nothing has fallen off.
I put a wrench on every bolt I could get to on the front suspension, but the only thing that turned was the cross bars under the exhaust. Now I can't get the car to make the noise, so it must have been those cross bars shifting or something.
