It's almost that time of the year again...
What tires are you going to go with for the winter time?
Specify size and post a review if you've ran them before. I'm fairly new to evo's and I'm gearing up on ordering my first set of winter shoes. I'm interested in opinions of people who actually have to deal with decent amounts of snow and what setup works best. I'm thinking about downsizing to a 215/50/17. I'm liking the look of the tread pattern on these and the price is right. They have some nice wide grooves on the shoulder. http://www.discounttiredirect.com/di...0&rd=17&cs=215 http://i109.photobucket.com/albums/n.../kumst1ang.jpg |
No can do...I don't think you can fit into the 17"s...doesn't fit over the Brembo brakes. I was thinking the same thing, as I've always downsized tire size in all my other cars but after lots of research the final conclusion from everyone was that I could not fit 17's (I drive a 2008 EVO MR)...I also have 17's from my Sebring and no way would they fit my EVO brakes when I put them side by side....there is only about 1/2 of an inch from Brembo brakes to the 18 inch rim as it is.
I'm in the high snow and ice belt in Ottawa, Canada. I Just got my tire order delivered last evening...bought the Blizzaks WS 60 as they are one of the best for snow and ice and are still at a decent price (they are huge, but will keep me gripped to the road)...I googled every site I could find on the topic. You won't find steel rims either...they only have that in Japan for the EVO's...you will have to go with the aluminum rims...buy the cheapest ones if they salt your streets as they will be eaten away by the salt and then look like garbage in a few years anyways, regardless of what you paid...ask for the "winter recommended" rims...not every rim does well in winter and usually there are only 5 out of 100 that any good rim dealer will recommend for winter. Don't know if you plan on using your stock rims, but for the same reason, I think you might want to purchase a second set of cheap rims for winter driving and also you don't want to ruin your summer tires having them removed and replaced all the time...this process also does damage to your rims. It was also recommended that I could find a set of old stock rims and put new tires on them, but that is hard to find in areas like yours and mine where there are few EVO's around. I bought 245/40/18, and 8.5 in rims...just as the owners manual said to do...don't want to order tires on-line and they not fit...especially way up in Alaska or in upper Canada, and the on-line prices are usually the best. Good luck. |
My winter tire are the Bridgestone Blizzaks in a 245/45/17. They are the **** in the snow. Id recommend getting those. The Yokohama Ice Guards are pretty good too. I don't have any other personal experiences with winter tires. Good luck.
Aaron |
Actually those will fit because he stated he drives and evo 9 which comes with 17s stock. He does not have a X.
Originally Posted by coryl
(Post 7523807)
The word "downsizing" got me then. I guess the two replys so far own and therefore would recommend the Blizzaks. In the on-line reviews, there are other good tires out there such as the Yokohoma Iceguard, the Michelin Pilot PA3, and the Pirelli winter carving, etc, but all are higher in price than the Blizzacks, which have great reviews and usually a much better price.
I was thinking of going skinnier partially because I see the snow rally cars with skinny tall tires. I assume it is the allow for more weight per square inch of contact patch on the tire to make it cut through the first few inches of snow to something more hard packed it can bite. Either 225/50/17 or 215.
I might go stock size I couldn't see going wider than stock for sure. I drove around a little on my 255/40/17's at the end of last winter and that was definitely too wide for the ice/snow. I plan on getting a second set of wheels for the winter tires. |
Rule of thumb: skinnier winter, wider summer. 225/50 has been done. I am unsure if a 215 will fit the 8in rim width. Neal can chime in on that.
Other brands - Dunlop winters, B'stone Blizzak, General, and Continental. Since you are in AK - can you run studded? --- When I lived in MI with my Evo, I just ran good all-season tires. I never got stuck - and I was lowered. But AK, might be a bit different. Snows would be well used there. |
I can run studded from October to April. One of the reasons I wanted to go to 215 was the tire selection changes drastically based on the size. There's not many aggressive tread patterns available in 235 or 225. Most of them look like regular all seasons with a different rubber compound made mostly for driving on already plowed roads. My road is often one of the later ones to see the plow. The 215's I found are also studable while most of the standard evo size tires are not.
I have a 10 degree incline on my dirt driveway and my road to access the local highway is also inclined. We get frequent snow, ice, and slush. I just want the best snow performance I can get to ensure I can make it out to work and what not when the going gets rough. We got dumped on pretty heavily last year. If someone could chime in on if I could mount 215/50/17's on 17x8" wheels that would help. I would assume that I could because it's one of the options on the search after already entering the vehicle model. |
Originally Posted by SmikeEvo
(Post 7524289)
Other brands - Dunlop winters, B'stone Blizzak, General, and Continental. Since you are in AK - can you run studded? --- When I lived in MI with my Evo, I just ran good all-season tires. I never got stuck - and I was lowered. But AK, might be a bit different. Snows would be well used there. I have mounted Blizzaks in a 215 on a customers Evo. While we do not recommend it, it is possible. I personally run the Blizzak LM-25v in a stock size, and could not be happier.{thumbup} |
Originally Posted by revvin9k
(Post 7525144)
i have a set of michelin x-ice tires. they are great!
its premounted on steelies. 18 inch im thinking about selling them. anyone here interested? |
Originally Posted by whitelancerGTS
(Post 7525456)
its premounted on steelies. 18 inch im thinking about selling them. anyone here interested? Where did you get 18 inch steel rims? I couldn't find them anywhere and I called all over Canada and the U.S...I was told that they do have some in Japan, but I wasn't going to go there. |
I have the Blizacks that came on the car when I bought it. OEM size. I'm actually kind of axnious to take off my Z1's and looking forward to some snow. The thing with snow is, around late Novemeber, early December, I'm super excited for snow. By mid Januaray, I'm sick of it and ready for spring. I'm usually itching to put my RPF1's with Z1's back on by February... but I can't :(
Im still using continental contiextreme. Tires are still in excellent condition lol. They are A/S, no probs with noise on dry roads, traction is good on slush/water, but snow you cant go too crazy but just learn how to control the car when it drifts. During the past winters since I got my evo, it has been mostly dry winters, and when it does snow, it snows hard. But I never have probs getting out of deep snow with these tires.
(Post 7525144)
| All times are GMT -7. The time now is 01:15 PM. |
