-   Evo Tires / Wheels / Brakes / Suspension (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension-23/)
-   -   6 Piston BBK's (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension/454008-6-piston-bbks.html)
Tonba Oct 21, 2009 03:40 PM
6 Piston BBK's
Hey all.
As I run my car in time attack, and do a fair chunk of circuit, I have been looking at BBK's to fit under 17" rims. (I use Nissan Skyline R33 GT-R 17*9" +30 rims as my track rims)
The brands Im looking at are Alcon, Endless and AP Racing.
Do you guys believe there is another brand I should be looking at. The main reason Im upgrading, is Im sick of loosing my brakes, and I think it would be a good idea to give my brakes a bit more headroom, especially with my additional power...
Who is a good vendor that sells these kits?
What do you guys use?
ChuckP Oct 21, 2009 03:42 PM
Step up to an 18" wheels with those 6pot
Tonba Oct 21, 2009 03:50 PM
^ I would mate... but I cant afford it.
I have 18" street rims at the moment.. but I jsut cant afford the $$ for track 18's at the moment.. especially with my rebuild going on..
revvin9k Oct 21, 2009 03:52 PM
Is it even possible to fit BBKs on 17" wheels?
EvolNinja Oct 21, 2009 04:01 PM
I don't think it will fit into 17" wheels. Gotta go with 18"?
nothere Oct 21, 2009 04:02 PM
have you tried two piece rotors yet, with stock calipers?
what are the stats on the R33 rims?
Tonba Oct 21, 2009 04:07 PM
Sure is!!
Here is a picture of a car in queensland (northen australia) running the Alcon 6-piston brakes with 343mm rotors...
http://i332.photobucket.com/albums/m.../DSC01208a.jpg
http://i332.photobucket.com/albums/m...MG_1396_25.jpg
revvin9k Oct 21, 2009 04:09 PM
^^^^ Wow, that looks crazy!!!!!!!!! :eek:
Tonba Oct 21, 2009 04:14 PM
^ Yup...
Which is why im looking for the biggest combo I can fit under 17's...
Some classes of racing, also require stock rim + offset...
Tonba Oct 21, 2009 04:21 PM
Not true. As long as you can stick to Alcon, Endless or AP Racing, you can fit rotors up to 343mm in size and still fit a 17" rim!
Reason being, is that the 'race' style calipers that those manufacturers offer are slightly more compact then the cheaper brands...
Check first post champ!
17*9" +30 offset. I run 255/40R17 Bridgestone RE55S on the track..
nothere Oct 21, 2009 04:23 PM
think of weight and cost more than anything else.
Sharkbite2000 Oct 21, 2009 04:27 PM
Dam that's a close fit!!! paper tight!!
Tonba Oct 21, 2009 04:37 PM
Huh?
Sure is.. Like 1~2mm of clearence or something like that... :D
Just make sure your wheel weights are not on the inside of the rim..
Jeff_Jeske Oct 21, 2009 04:38 PM
If you are interested in the ALCON kit you should PM ExtremeDSM. He has a set he is looking to sell.
Girodisc Martin Oct 22, 2009 11:27 AM
What where yo using with your current brakes and how did they fail? We offer only parts to improve your stock calipers and many of our customers get steller results 500whp time attacking etc... With a 6 Piston kit you are not increasing the rotor very much so the upgrade in braking is in the sizing of the pistons. It will give you more clamping force but your stock Brembo Calipers are quick large and there are many things you can do that can drastically improve the performance of them.
You should PM me and let me know what you are having problems with your current setup. There is a good chance we can fix you up and save you a bundle over a BBK. BBKs are expensive initially, but you have to also take maintenance into account. Pads are more expensive, as is the rotor. Depending on the type of BBK you get you also have to account for availability and wait time for those parts. Not trying to sway your decision but if we can help and save you money then its worth at least exploring.
Johann @ Girodisc
