Mullerized JIC's? Thoughts, opinions, feedback?
Currently i have a set of BC racing coils. i have only had them 6 months or so, but have already found that they arent that great when it comes to autox. i have a LOT of body roll, even when adjusting the stiffness setting.
Next year at autox is going to be VERY competetive. There is a pesky Evo X that beat my ass last year, so im trying to not let that happen again. so i have been thinkin about a new setup, and saw the mullerized JIC's. I know Muller does some GREAT work, but wanted to see what you guys actually thought, and had used/trusted. thanks! p.s. other mods on my car are - Whiteline rear sway Whiteline bump steer kit (I HATE IT!!!! makes the car bouncy) Whiteline Roll center kit. |
12k front / 16k rear - KW3s. Massive Hoosier A6s. Done.
how massive of an a6 you think i can fit?
Originally Posted by luckybull
(Post 7836821)
(Post 7837126)
Beyond them, widebody kit, or winder fenders are needed. |
I have run a couple of different Muellerized setups at the track and have had a lot of success. I cannot speak to the JIC's specifically, but I would not hesitate to recommend their services
after smike evo's post, i checked on the kw3's. the kw's are actually cheaper, and i have heard alot of good things about them.
dont know now! lol! all i know is i need a better coilover than the bc! |
(Post 7836821)
We've run 12k/16k on KW's, and it's definitely pushing the valving at those rates. For your uses, it might not be the best choice. I don't have any experience with Mueller's JICs. I'm not really a fan of standard JIC valving......his must be a lot better. - Andrew |
12/16 is definitely not off the shelf. And really, thats an AX spring rating. In the end, a correctly valved and setup KW is probably the same as the same setup JIC.
285s can fit, but lots of rolling and some hammering will be needed. |
hmm.. now its a toss up between the two. i know mullerized knows his stuff, so im kinda still leaning that way, as they will be already setup for me.
(Post 7837283)
dont know now! lol! all i know is i need a better coilover than the bc! I also wouldn't get the standard valving from what I've read. Notice SmikeEvo and Drew@GTWorx both mention custom valving those. KW's usually go to people that want to tweak their setups continuously as they have a LOT of adjustment options. If you don't want that - and have raised your pricerange up around $3k - check out Ohlin DFV's. |
I was also in the same situation as the OP. I had BC coilovers that worked fine (IMO) on street tires, but on R-comps, there was a lot of body roll even with a rear anti-sway...
I just picked up a set of Robispec'd KW3's with 8k F / 9k R springs. I'm really wondering if I should go with a higher spring rate before I get these installed. I'd still like to keep it somewhat streetable however, but I don't want much body roll during autox on r-comps. Otherwise it just seems to prematurely wear the outter edges, even with quite a bit of camber.... |
I run muellerized stage 3 w/JICs car handles great.. pulled some quick times at Big Willow on some very worn and heat cycled RA1s.
What class are you racing in?
I'd vote skip JICs altogether, KW v3 at the minimum. I'm driving on JICs right now and raced STU on them for a season. Not Muellerized to MY specs, but they have been Muellerized before, and there is a limit to how much you can optimize, Muellerize, or fix JIC valving, even if you're Mueller. |
ill be in SM next year.
hmm.. not sure i want to dish out the 3k for kw's though. |
Luckbull, PM sent. We may have just the solution for you.
| All times are GMT -7. The time now is 05:33 PM. |
