X BBS Wheels on Evo 8 Question
I just bought a set for my 04 RS and had a couple of questions.
1. Can you use stock lugnuts from 8 Enkei? 2. ANyone ever use spacer? If yes how big can you go or suggest? I wanted a more agressive look so was considering using spacers. Wheels are 18x8.5 +38 I believe. Thanks |
stock lugs will work
spacer you could go up to 8mm before you'll need to roll the rear fenders assuming you are running a 245+ tire and you are lowered if you want a more aggressive look why buy a stock wheel set? |
Thanks for the input! I got a pretty good deal on the wheels so I figured I would try them out and trade up if it was too simple looking. I will be running a 245/40/18. If I rolled fenders, could I go 15mm?
bump
If I rolled fenders in rear, could I go with a larger spacer? ANyone use a spacer with this set up? |
You may be in un-chartered territory. Im running the X wheel w/ a 255/35 tire & Ive tried a 5mm spacer but ended up removing them due to vibration (Rear fenders not rolled)
The X BBS is the same spec as the GSR (as far as I know) 18 x 8.5 +38. By adding the 15mm spacer you are effectively running a +23. Give it a try!!! You may need aggressive rear camber to make it work right. I would think the fronts would work well Peace |
Cool, thanks!Ill try the 15 and if it doesnt work, ill go with rolling the fenders next.
^^^My good guess is that you will certainly need to roll the rears
Love to see it after the install=) |
