-   Evo Tires / Wheels / Brakes / Suspension (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension-23/)
-   -   Rear Upper Toe Control Arm Cracks (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension/563976-rear-upper-toe-control-arm-cracks.html)
scherejs Jul 7, 2011 10:32 AM
4 Attachment(s)
Started to install Energy Suspension Bushings today and noticed this:
Attachment 172832
Attachment 172833
Attachment 172834
Attachment 172835
Both driver and passenger side is like this. I assume I need to replace both arms? What would cause this?
shadow1 Jul 9, 2011 08:22 PM
Yikes. Definitely you need to replace those "toe" arms. I've never heard of this happening. Were these hammered on in the past?
scherejs Jul 9, 2011 09:55 PM
They shouldn't have been. They've never been off the car. The only thing that has been done to the rear is brake pads. That's why it's got me stumped on how this could have happened. I noticed that I spelled "toe" wrong after I created the original thread, but couldn't edit it.
Stan C. Jul 12, 2011 06:04 PM
Wow
Wow haven't seen that before. I got some used ones for sale if you still haven't changed them.
scherejs Jul 14, 2011 06:21 AM
Thanks, but I've already got them swapped out. I had never heard not seen that either.
Yogi_B Jul 14, 2011 09:36 AM
Guys over in the UK have had problems like this, on the bush end too and they have also had problems with the upper arm cracking aswell.
It always cracks along that forging line but the arms that tend to crack over there are the evos that are driven during winter lots as corrosion sets in and weakens it there.
scherejs Jul 14, 2011 02:41 PM
Mine has had many miles put on it in the snow and salty roads. Maybe that was the problem. I really don't know, I just hope I don't have it happen again.
mithrandir7533 Jul 15, 2011 11:07 AM
Those parts are aluminum, I don't think rust and corrosion would affect them. Are you the original owner of the car?
Do you track your car? I would think the car would have to see some severe stress for that to happen. Might possibly have been defective from the factory.
Ayoustin Jan 2, 2019 06:16 AM
Necrobump. Just found one of mine cracked the other night. Check your arms people!
https://cimg2.ibsrv.net/gimg/www.evo...5d3b0121a.jpeg
MinusPrevious Jan 2, 2019 06:26 AM
Good catch. This failure is likely more common than whats been reported :crap:
LetsGetThisDone Jan 2, 2019 09:53 AM
I have hard race rear toe arms. The stock ones came off at 55k miles with no apparent issues. How many miles on yours? Lots of track use?
Ayoustin Jan 2, 2019 10:11 AM
Bout 110k, tons of track time over the past 6-7 years.
LetsGetThisDone Jan 2, 2019 10:23 AM
Would probably just chalk it up to fatigue over time. With track use, it is being subjected to much harder impacts (and much more often) than it was really designed for...
Ayoustin Jan 2, 2019 10:28 AM
Yea it's not mindblowing or anything to see this, just haven't heard of it being a problem before.
MinusPrevious Jan 2, 2019 10:31 AM
Just want to make sure which arm failed on your susp
Trailing arm? (Dallas's arms) Item 1
or
Upper link Item 2
https://cimg9.ibsrv.net/gimg/www.evo...e16267f91a.gif
