WedsSport TC105n 17x9 +35
I am in need of new wheels after a hit 'n run.
I am thinking of going with the WedsSport TC105n in 17x9 +35. I have seen Evo 8's and 9's on the 17x9.5 +32 and I really like the look. I however do not like the look of the 17x9 +25. Its just personal preference nothing else. My RS is NOT lowered and I do not want to lower it. I think the 17x9 +35 will just look "right" at the stock height. Would a 17x9 +35 work without fender work or spacers? I have 17x8 +30 mounted now and according to my math a 17x9 +35 would only "stick out" 8mm further which is what I am looking for. Thanks for all the help, I hope I made myself clear. |
yes, +35 is the perfect offset for a 9" wide wheel. +30 will occasionally touch the fender with a bigger tire.
edit
Bump - Before I buy these I want to make double sure these will fit w/o a spacer up front or rolling in the rear.
I have searched all over and have found this link: http://www.mitsustyle.com/forums/showthread.php?t=30380 That is the ONLY confirmed fitment, and it doesnt even suggest he was using a spacer. Thanks for any and all help! |
Originally Posted by Russell K
(Post 10097283)
Yes 17X9 +35 will clear your Brembos in the rear. I suggest minimal rolling in the rear but its not necessary. The Fronts will need a 3mm spacer.
Originally Posted by n2oiroc
(Post 10097291)
no rolling in the rear for sure, i cant help with the spacer thing in the front though, i know it will clear the strut, but i dont know about the caliper.
Originally Posted by deylag
(Post 10097320)
Yes 17X9 +35 will clear your Brembos. I suggest minimal rolling in the rear but its not necessary. The Fronts will have no problems.
If anyone has any pictures of any TC105N's mounted on an Evo 8 or 9 plz provide a link. Not only for me, but for other ppl who may be searching for this answer in the future.
(Post 10097519)
1 Attachment(s)
Here is my car with TC105N's, they are 17x9's. No fender rolling required on 245/40R17. Unfortunately I don't know the offset, my car came with them.
Originally Posted by Ang Wen Yan
(Post 10100364)
STM's Street RS use 17x9+35 TC105N
Thanks for the info though, I almost positive +35 TC105N will work on the front. I have found this link: http://www.mitsustyle.com/forums/showthread.php?t=30380 No one else seems to be running a 17x9 +35 on the front besides the guy above. |
Originally Posted by jfontenot
(Post 10101129)
https://www.evolutionm.net/forums/ev...cs-my-pos.html |
I believe the +35's require at least a 3mm spacer to clear the front Brembos.
I know the owner of the car you linked and he matched the spacer in the rear so the track width stayed the same from front to back. |
Originally Posted by BriK
(Post 10102369)
I know the owner of the car you linked and he matched the spacer in the rear so the track width stayed the same from front to back. I have been looking for the answer to this. Wow - This is hard - Pickin' a wheel with the offset you prefer. |
