-   Evo Tires / Wheels / Brakes / Suspension (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension-23/)
-   -   Creaking from Driver's Front when Turning (https://www.evolutionm.net/forums/evo-tires-wheels-brakes-suspension/612161-creaking-drivers-front-when-turning.html)
eric6 May 16, 2012 10:24 PM
http://www.youtube.com/watch?v=1SYzA...ature=youtu.be
Noise is only present with the car on the ground. Once lifted up, no creaking can be heard. Bumps do not seem to effect the noise, only turning. No slop in the left front wheel when in the air (wheel bearing and tie rods both feel solid), I got under there with a pry bar multiple times only to find nothing that replicates that sound when moving things.
Stance coilovers, whiteline tie rods/ball joints, any ideas?
eric6 May 16, 2012 10:27 PM
I'm thinking of buying a used rack as I think its coming from the ps gearbox itself.
Edit: I've touched the coilovers while moving the wheel, I don't feel any vibrations really.
Russell K May 20, 2012 08:25 AM
Sounds like the Whiteline Ball Joints to me maybe?
Beebo05 May 20, 2012 08:35 PM
seagulls?
NocturnalEVO May 21, 2012 08:42 PM
I'm curious as well. I have a similar noise also. I'm running bc racing coils and a whiteline roll center kit. Haven't been able to figure out what's causing the creaking.
Piro Fyre May 21, 2012 09:28 PM
I had creaking issues but it never squealed like yours. Eventually, I heard a pop and the creaking stopped. Found out it was because of this:
https://www.evolutionm.net/forums/ev...uck-again.html
Now, I'm in the process of replacing the k member/subframe...
eric6 Jul 22, 2012 11:02 AM
THATTTTTT^^^^^^^^^
GRRRRRR. Yep, just found out when doing a Perrin PSRS and steering rack. What a way to end 5 hours of torture =P.
