Help with STANCE combo.
Hello guys,
I have a 1993 GSR which Im soon going to convert to 5 stud for wider choice of wheels. I would like to get the widest rim possible to fit (8" ?) with a slight tyre stretch (215/45 ?) in 17" Can someone confirm if this will work or can recommend a tight fitting combination? Also what offset would work to pull this off ? Guards will also be rolled, so no need to worry in that aspect, and car is sitting on coilovers for maximum clearance. Thanks in advance! :D |
Thanks, i appreciate the link to forum wheel calculator.
Maybe i didn't explain my question properly. Im after comments from owners of evo 1,2,3 who managed to pull off stance wheel/tyre combo. Which can't really be calculated as easy with a calculator i guess :S |
