Alignment Dilemma
I need some good information. My front tires had the tread separate from the carcass after only 15-20,000 miles. I upgraded to 18s but the suspension (and I alignment I believe) are stock.
Is there a magic setting(s) that eases the leverage put on the front rolling stock? |
What are your alignment settings?
A bad alignment may cause excessive or non-uniform tire wear, but it will not cause the tire tread to seperate from the carcass.
If the tire tread seperates from the carcass, that's a defective tire. Contact the tire manufacturer. |
