Endless Big Brake Kit - Replacing Endless rotors with another brand?
Hi guys,
My front and rear Endless rotors are now needing replacing. I was wondering if anyone knows (or has) replaced Endless rotors, with something like DBA, Project Mu, Alcon, etc? Its getting a little bit pricey at ~$750 per front rotor so i was wondering if there is any other options. My question mainly has been around compatibility with keeping the Endless calipers/pads, but just running a different rotor. I'm running 345mm front rotors and 320mm rear's (both 2 piece) Could anyone suggest any suitable replacement rotors that are cheaper than the Endless ones? I'm happy to keep the hats and swap the rotors (if possible) or just replace everything in one go with a 1 or a 2 piece option. The car is no longer tracked, but may be participating in some autocross later on in the year. Cheers! |
The ENDLESS 345mm disc for their kits are a "one-off" sizing and PCD. You wont be able to find a directly replacement for those units.
They are an extremely high quality disc, hence the price. Have you had disc wear problems? What compound are you using? |
