RPF1's questions
I'm currently running RPF1's on my evo 8. They are 18x10 +38. And tires are Dunlop Z2's at 265/35/18's. I've been having rubbing on the Inside of my rear driver side wheel. Also rubbing on the outside of the front passenger side tire. I am lowered on coilovers. I'm not sure if I should try raising the car up to ride higher or if I should replace my coilovers with a different brand.
In the rear you mine be hitting the LCA. Are you catching the front fender up front?
Off topic could you post pics please... I love rpf1 in 18x10+38 |
You need a 5mm spacer for the rear not to rub on the trailing arm.
Evo
1 Attachment(s)
That's it on coilovers. No in clearing the LCA's in rubbing a 5mm spacer in the rear so I can clear it. And the front I my rubbed at full turn, turning right.
1 Attachment(s)
Same car
looks good, what spacers are you currently on?
I run the same wheel with a 285/30-18 ZII. 20mm spacer up front, 5mm spacer in the rear. No contact in the rear at trailing arm. Some liner contact up front on one side.
| All times are GMT -7. The time now is 07:16 AM. |
