Rebound settings
To make it short, on the evo 8/9 is it better to have a stiffer rebound on the rear coilovers than you have in front, or the opposite, or to have them equal.
depends on the kind of use the coilovers will get
Originally Posted by llDemonll
(Post 11302469)
(Post 11302469)
If my notes are correct, Terry at FA had me start my clickers at 15 front & 18 rear but Im second guessing if my notes are correct In for more comments |
I run stiffer in the rear than the front for both street and auto-x. I just reduce the harshness for the street. I'm on a square spring setup with a Whiteline 26mm FSB and a Whiteline 24mm RSB on full hard. I would suggest starting with even settings as the safest approach as it should yield understeer instead of possibly snap oversteer. As a final note, a 27mm rear bar is HUGE.
Originally Posted by terror rising
(Post 11302652)
Originally Posted by Viegasjuice
(Post 11302691)
I realize that, but is that a bad thing? I'm new to suspension the 27mm bar that is.
Just called Chris at FA. He noted, on the EVO you generally run more rebound in the rear vs front
Std settings on their C/o's are 8 front / 12 rear to start (approx 30% diff) |
Originally Posted by Solenoid
(Post 11303059)
(Post 11302820)
The 24mm bar will be aggressive enough you. I run that as well
Just installed my 500's last week. I started with the factory settings 5/5 (daily driving, nothing too aggressive yet) but felt a bit soft/bouncy... I went up to 10 front/10 rear and thought they felt pretty good. I tried the 8/12 and didnt think I was liking it so I went to 8/10 to give it some time to decide.
What spring rates you guys on? I'm on 8k/9k |
Originally Posted by Walker
(Post 11304766)
(Post 11304692)
Could you explain to me the difference that it will make in the car? Thanks
I would call Terry at FA to double check |
(Post 11304843)
Prone to more oversteer. IMO, running 10K in the rear & running a 27mm bar could be a recipe for trouble
(Post 11304843)
I would call Terry at FA to double check the FA's should have rear helper springs, but i dunno how much droop they have. i have never lifted my inside rear. |
