Best Suspension For Road
Hi
I bought a Evo 6. Previous owner installed full racing Tein shocks. Im not sure which type of Tein shocks are installed. Maybe I can figure that out somehow so I can sell them? I can feel every bump in the road, really not good for street use at all. It so hard its destroyed the steering bushes What should I get to replace them? I live in Thailand, the roads are pretty bad. Should I get rally shocks? Or whats the closes aftermarket part to the shocks that come with the Evo as standard? Is that the way to go? Or something in between? |
In your situation, maybe installing the stock suspension is your best choice
or, installing the stock suspension & using a lowering spring (i.e. GTWorx or Swift spring) |
i agree with joe
The stock suspensiom is long gone. I don't have it. Evo aren't available here they are all modified lancer. Nobody importing standard suspensions
A lot of us run Fortune Auto coilovers. They have a dealer in Thailand (Kudos Motor Co. LTD)
https://fortune-auto.com/dealers/ I would call Kudos Motor. They can custom spring & valve for the T-Land road conditions. They do make coilovers for the EvO6 Just a thought |
Hello i may be of some help i live in the philippines and ive been to thailand a few times and i can say from experience that philippine roads are much worse than thailand roads. I too have an evo 6 and went with d2 street coilovers with 7.5kg springs. The ride is just stiff enough at its softest setting its just a tad bit stiffer than stock ive had them on for 2 years now no problems so far. Before the d2 coilovers i had hks coils which were way too stiff and harsh ended up ruining those switched to stock evo6 suspension then a set of tommi makinen edition suspension both rode well for older used sets but they soon blew out within a year each. Went with the d2 coils as they offer great aftersales support over here with replacement parts easily sourced tho i have not needed to get anything done since putting them on. Would recommend them if they have a dealer over there. If they can hold up to philippine roads im sure they would be great over there.
