Konig Hypergram Question
https://www.discounttire.com/buy-whe...ergram/p/47833
Hey guys, just wanting to get confirmation that these wheels would fit with any issues with my Evo 8. Think any spacers would be required? I wouldn't think so, but hey, that's why I'm here to ask. Currently running Rota D2 18x9 ET30 w/245/40/18 tires that I'll likely transfer over to these wheels. Been wanting to get a different wheel for a while and liked these and the price. Any input would be appreciated, thanks. |
The wheel youre looking at is very modest in size & offset (18 x 8.5 +35)
Should have no issues running those 245/40 tires. No rolling required The only issue is, its very likely going to need a front spacer. What size, is a guess unless you can do a test fit or find another soul who has installed them & knows |
Konig builds these wheels for brake clearance. I doubt you'll need a spacer. You can always call them and ask.
bump will the hypergrams in 18x9.5 +35 clear the X brembos?
The 18x10.5 +25's had room for dayyyyysss. I think someone else on here is running the 9.5 +35. Konig designs the for caliper clearance, I'm sure you're good to go.
(Post 11813982)
https://www.evolutionm.net/forums/mo...-wheels-2.html the 18x9.5 +25s seem close based on the thread above, not sure if they'll have 10mm to give extra clearance to calipers. |
Then run a 10mm spacer in the front :). You'll need to anyways for a 265/35r18 to clear the strut with a 35 offset wheel.
(Post 11815155)
i'll have to check caliper clearance as you said though. no response from konig. when it gets closer to time i'll just have to visit a shop that stocks them and check the clearance |
Wheels ordered today, pics to come :D
Originally Posted by SW20Mike
(Post 11818841)
Originally Posted by kyoo
(Post 11818900)
which size, spec, car?
Update, good news is wheels look great. Bad news, fronts did not clear calipers, barely... So having to order 5mm spacers and will update Monday when departs arrive.
https://cimg2.ibsrv.net/gimg/www.evo...c1aeb77934.jpg
Rear wheel, 18x8.5 et35, no spacer https://cimg0.ibsrv.net/gimg/www.evo...1372cba362.jpg https://cimg5.ibsrv.net/gimg/www.evo...b57b1a8d40.jpg Unfortunately fronts did not fit, will need 5mm spacer https://cimg1.ibsrv.net/gimg/www.evo...ba027cc9a6.jpg Rota D2 18x9.0 et30, 25.6lbs https://cimg3.ibsrv.net/gimg/www.evo...caa2523eb4.jpg Konig Hypergram 18x8.5 et35, 18.0lbs, saving over 7lbs per wheel from old setup! |
looks great. shame they didn't fit without a spacer. wonder if the 18x9.5 +35 will need a spacer, +25 is too aggressive
https://cimg3.ibsrv.net/gimg/www.evo...41640bb988.jpg
5mm spacers on the fronts So wheels are on, spacers on the front, and I'm very happy with how the car looks and feels. Can definetley tell a difference with the weight loss. My only concern now is the count of full turns I get with my lug nuts. I've read online that 5mm is safe on the stock studs, but I'm only getting a hair over 4 full turns torqued down. Do I need to get extended studs? I wanna be safe and say I should , input? |
